Home > General > newbie, swap disco 3 for ffrr???
bear100
hi guys i am a newbie to this forum, i am thinking of swapping my disco 3 hse for a tdv8 ffrr Idea , can you tell me what the mpg is, i have been looking at a 3.6 vogue se. is it a good idea to swap?, are they more reliable than a disco generally speaking of course?, are the servicing cost the same etc etc
Post #65248 22nd May 2011 10:41am
johnson1
Re: newbie, swap disco 3 for ffrr???
Hello and welcome Smile
What is the age and mileage of the FFRR VSE? I think you will notice a jump in costs - the 3.6 will cost more to run but is quite an efficient engine. VSE has plenty of toys to keep you happy and is a good buy. Check what warranty work the car has had done before you buy and try and buy from a dealer which will give you a warranty of some description. Servicing and parts will be more expensive on a Range Rover than a Land Rover - all to do with brand separation and the whole Commercial vs Luxury image that LR is portraying now. Probably costs them no more to actually do. There is more to go wrong on the RR than on your Discovery, particularly with the RSE etc etc that came with the VSE.
I'd go for it - in terms of refinement etc, the FFRR has no match.
Post #65255 22nd May 2011 12:09pm
bear100
Hi thanks for the reply, its a 08 with 50000 on the clock from a stealer asking £32k and six mths warranty.
what is VSE RSE
Post #65256 22nd May 2011 12:20pm
JustinP
RSE - Rear Seat Entertainment, which is the head rest mounted screens, wireless headphones and DVD auto changer.
Post #65257 22nd May 2011 12:29pm
johnson1
VSE - Vogue SE
Sounds a nice car and a good price Smile
Try and push for 12 months warranty.
Post #65258 22nd May 2011 12:37pm
bear100
what sort of problems are associated with RSE this is one of the reasons for looking at this rangie (for the kids).
will have to have a minimum of 12 mths warranty. anything i should look out for when looking apart from the obvious like off road damage, tyre wear etc.
i made the mistake of visiting the dealer to test drive the disco 4 yesterday, problem was they had a 2011 VSE demo parked next to it so had to have a test drive and i fell in love with it, it just felt they built the car around me!
i did test drive the p38 many moons ago and it was horrid so i have stuck with discos ever since.
apart from the engine and gearbox does the new range rover have same suspension set up etc, and is there alot of difference from the 4.4 to the 3.6
Very Happy
Post #65259 22nd May 2011 12:48pm
johnson1
No problems with RSE - have it in my car and it is a really good system - really good. Yes 12 months would be good. I meant the toy count is higher and just overall more things to go wrong than in a D3/D4.
Uh-oh!! You've fallen into the RR trap - you won't come out of it now. Nothing else will suffice. I too drove a P38 years ago and it was actually the most horrible car I had ever driven. I then associated the 'all new' Range Rover with this type and never got back into a RR until last year when I knew I had to have one.
Not sure about the technical ins and outs but the D3/D4 is more similar to a RRS than to a RR. The RR is a completely different setup in most things.
There is a big difference between the 3.6 and the 4.4. I test drove the 3.6 last year, and then the 4.4 when it came out. Whilst the 3.6 is good, if you have driven a 4.4 you will notice the difference. 3.6 is less economical, higher road tax band, and a second slower 0-62 than the 4.4. Only trouble with the 4.4 is the price as they do seem to be holding their values well - when I was looking there was also very little Autobiography 4.4s available 'nearly new' so ended up buying brand new and don't regret it Smile
Cheapest 4.4 on Autotrader is £60,900 at the moment as they only went into production around 2010/60 reg. Don't get me wrong though, the 3.6 and more importantly the car mated to it is still fantastic.
Post #65260 22nd May 2011 12:57pm
bear100
i fell into the range rover trap when i had my 1st classic range rover some 12 years ago, but the p38 was that bad it put off me them Crying or Very sad .
what sort of mpg do the 3.6's give? and are the autobiography's worth the extra dosh? what is different any Confused
Smile
Post #65267 22nd May 2011 3:13pm
johnson1
bear100 wrote:
i fell into the range rover trap when i had my 1st classic range rover some 12 years ago, but the p38 was that bad it put off them Crying or Very sad .
Smile
3.6 is around 24mpg, 4.4 is giving me around 28-29.
Depends what model years - pre MY2010 Autobiography was custom order and needed to have something different to get the badge e.g. non-standard paint finish. Specification was generally high.
MY2010 onwards - Autobiography gets you above VSE:
Dual View Screen
Adaptive Headlights
Full Leather Door Cards
Full Leather Pillars
Full Leather Dashboard and Console
Full Leather Headlining with Rear Vanity Mirrors
Autobiography Wheels
Two-Tone seats as a nco
Post #65272 22nd May 2011 3:39pm
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
I got 24 mpg out of my 2005 Disco TDV6 commuting on A3/M25. Now get the same from the TDV8, performance is significantly better though.
We dont use all the extra multi media very often on our VSE, so I am not sure we would spec that on a new one, it is cost option now any way. It used to be bundled on the older cars. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #65273 22nd May 2011 3:56pm
bear100
not to bad then i am only getting 22-23 with my disco 2.7 tdv6 Embarassed
just need an extra £30k for the 4.4 to be in my price range Big Cry
Post #65274 22nd May 2011 4:04pm
azure111s
Had 2 D3s myself in the past. A mate has a 2010 3.6 VSE and I love that. Also loved the '07 Vogue he had before that. Very different vehicle to a D3 (not that D3 is in any way bad, of course!). Just dipping my toe in the water now and ordering a new 4.4 VSE Smile
Post #65360 23rd May 2011 10:50am
bear100
Dipping hour toe in Whistle new 4.4 VSE you Jammy jammy barstool Big Cry
Any one got 30 grand they font want
Post #65375 23rd May 2011 12:08pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I am very lucky enough to say we have both Very Happy
My wife has the 2008 D3 HSE and my "newly aquired" 2010MY FFRR VSE Thumbs Up
Completely different cars but I have to say I love driving them both with very little to choose between them on fuel economy.
If one had to go though I would find a suitable "crash helmet" to wear before shipping out the D3 Whistle
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #65435 23rd May 2011 4:15pm
