![]() | Home > Technical (L322) > Help!!!! TDV8 issues |
the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50 ![]() ![]() ![]() |
some pics of what the error reader is sayign
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Have you checked you battey voltage, if its low you will get all sorts of ghost codes. You should be looking at 12.3 volts + for a good battery. |
battery voltage is good even had it hooked up to the charger to make sure |
a thread resarection here, with an update i forgot to post some time ago.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
At least you sorted it in the end. Those type of things can be a pain to find. Back in the 80s a friend of mine had a series 3 Jag XJ6. Was lovely…. But would just die randomly as you were driving… all of it….. after much investigation over months, was a short at the back of the dash.
