Home > My Range Rover > New to me UK RR Vogue SE (2012) - Some questions too :)
DrRob
You can look up any fault code in the workshop manual which is downloadable from the Wiki page Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601606 23rd Jul 2021 3:38pm
tezza
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Orkney Grey
I have those from the diags
C1A13 Pressure does not decrease when venting
C1A36 Exhaust Valve
Post #601613 23rd Jul 2021 4:22pm
mjdronfield
I’d just drill a hole through the filter.... definitely can’t be that then..... No issues from mine after doing it.
Saved over £700.....
Worth a try. Costs nothing....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #601614 23rd Jul 2021 4:26pm
DrRob
Agreed. Drill a small hole all the way through the sintered brass valve after removing it off the compressor Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601622 23rd Jul 2021 5:32pm
tezza
No joy, still faulting but I've lost access to the diag reader now. I'll book it in to be looked at but thanks to all for suggestions.
Post #601631 23rd Jul 2021 6:25pm
mjdronfield
I think you’ve pretty much done all you can regarding an easy fix you can do then.
Worth a try before moving further....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #601633 23rd Jul 2021 6:40pm
tezza
Yup cheers for the suggestion. I wonder if I should replace that silencer before taking it to the dealer since I've drilled a hole in it but I am kinda confused on this.
I see this part https://www.lrparts.net/rqv500040-air-susp...-2012.html
and also https://www.lrparts.net/lr025940-silencer-...rover.html
And for this one https://www.brit-car.co.uk/product.php/166...over_vogue it looks like someone has already taken a drill to it.
Post #601646 23rd Jul 2021 7:22pm
mjdronfield
I wouldn’t bother replacing it. It’s sorted a potential issue and I doubt they will know it’s not been like that for years. Having a hole in it will not cause any issues.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #601647 23rd Jul 2021 7:42pm
dingg1
Try it without the filter Whistle
Probably be OK ime
Post #601649 23rd Jul 2021 7:50pm
