Home > My Range Rover > New to me UK RR Vogue SE (2012) - Some questions too :) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
You can look up any fault code in the workshop manual which is downloadable from the Wiki page Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Jul 2021 3:38pm |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 |
I have those from the diags
23rd Jul 2021 4:22pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
I’d just drill a hole through the filter.... definitely can’t be that then..... No issues from mine after doing it.
23rd Jul 2021 4:26pm |
Agreed. Drill a small hole all the way through the sintered brass valve after removing it off the compressor Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Jul 2021 5:32pm |
I think you’ve pretty much done all you can regarding an easy fix you can do then.
23rd Jul 2021 6:40pm |
Yup cheers for the suggestion. I wonder if I should replace that silencer before taking it to the dealer since I've drilled a hole in it but I am kinda confused on this. I see this part https://www.lrparts.net/rqv500040-air-susp...-2012.html and also https://www.lrparts.net/lr025940-silencer-...rover.html And for this one https://www.brit-car.co.uk/product.php/166...over_vogue it looks like someone has already taken a drill to it. |
23rd Jul 2021 7:22pm |
I wouldn’t bother replacing it. It’s sorted a potential issue and I doubt they will know it’s not been like that for years. Having a hole in it will not cause any issues.
23rd Jul 2021 7:42pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Try it without the filter
23rd Jul 2021 7:50pm |
