![]() | Home > Maintenance & Mods (L405) > Main dealer 80k service quote |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
So one of my clients has a 65 plate 4.4 AB which he bought on my recommendation last year - it went in yesterday to the supplying LR main dealer for some refurb. work on the alloys and to be given a health check in advance of the 60month/80k service - its only done about 30k though. He also reported a bit of a whine at speed.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8519 ![]() ![]() ![]() |
Dealers are hurting at the moment, I expect we will see more and more of this as they try to claw back money, only a few will question them, so as usual, they will get away with it...
You don't run most of my fleet without being on first name terms with a good indy and knowing where to get good quality cost-effective parts from - my 2004 L322 has over 200k on the clock and still in daily service.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
I paid £315 at an Indi specialist for an 80k service. They even updated Topix. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
nbunney Did that include the dynamic response service? New reservoir as well as the diff and transfer box oils?
No to:
Renew Dynamic Response fluid reservoir
Can confirm the Dynamic Response reservoir replacement is on the 80k schedule as TJH has said.
I don't like to cast aspersions on main dealers or anyone else but a few facts
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 986 ![]() ![]() |
Site sponsors and this is for discs and pads not just pads.
I have actually just been back and watched the service video from our 80k service, often our MD starts the video by showing the parts on the bench to be changed in this case I can confirm they at least had the right oil on the bench ready ![]()
I think they are wise to this sentiment now, the video's we get tend to show the work in progress so parts on the bench ready which the technician calls out what's what and then the car on the ramp with either the drain plugs out or whatever the part is removed. Like so: ![]()
At first I kinda rubbished the video's, but now I kinda like them. We had a issue with the EGT Sensor and the video from the health check gave some useful / intresting insight into the diagnosis the technician went through the various things it could be and how he ruled out each one etc. Also handy for when someone on a forum makes you question if you have the right oil in the car ![]() ![]() ![]() Btw.. don't think I am defending main dealer behaviour here, I have my own issues with them ![]() Spec's: https://topix.landrover.jlrext.com/topix/s...fef/en_GB? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 ![]() |
Really interesting that TJH - funnily enough I didn't get the video on my service last year - the car was in the dealership for 7 weeks - you can read the full saga in my My Range Rover post https://www.fullfatrr.com/forum/topic40798-90.html and conveniently the video had already been 'deleted' when I started to question things.
I beg to differ. Here is my schedule off Topix: Service schedule Customer copy SERVICE TYPE: 80000 miles / 60 months service V.I.N.: MODEL: Range Rover / L405 Please note that service intervals always represent the time and distance that should exist between servicing. Driving style and conditions may maximum necessitate earlier servicing as indicated by the notifications on your instrument panel. SERVICE ITEMS Check condition and security of seats and seat belts. Check operation of all lamps, horns and warning indicators. Check operation of Windshield and headlight wipers and washer jets. Select the LOW range gears and drive the vehicle 3 to 4 vehicle lengths then re-select HIGH range gears. Renew pollen filter. Check tire pressures, condition, tread depth, signs of uneven wear and suitability (including spare). Remove road wheels. Inspect brake pads for wear, calipers for leaks and disks for condition. Drain fuel filter water trap. Refit road wheels to opposite sides of the same axle (Use anti-seize compound on spigot bore). Check torque of towbar fixings (where fitted). Renew Dynamic Response fluid reservoir (where fitted). Check/top-up brake and Dynamic Response fluid levels and screen washer reservoirs. Renew engine oil and filter. Check for debris from auxiliary oil cooler and radiator. Renew transfer box oil. Renew locking differential oil. Carry out road test. Reset service indicator. Reset engine oil level indicator. Endorse service record. Report any unusual features of vehicle condition and additional work required. OPTIONAL SERVICE ITEMS If fault lamp(s) are illuminated, interrogate that system using the JLR approved diagnostic equipment and report findings.* L/F R/F L/R R/R SPARE Tyre Pressure Tyre Tread Depth Tyre Condition |
It’s in that list though nbunney? Unless we have our wires crossed here and are talking about different things.
Also assuming you have a SDV8 as well? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 ![]() |
