Home > Technical (L322) > Second Compressor Install/Mod
dan_uk_1984
The Plan:
To install a second compressor, in-line to the main one.
The Reason:
Faster suspension changes and increased critical system redundancy. I also aim to use one of the newer designed pumps from the 05+ as I'd like to think that any technical developments have been incorperated into the new pump.
How:
T piece into the air line, run a separate 12V feed to the second pump via a relay, using the signal to the first pump as the switch.
Help?:
A). What Amperage do the EAS pumps run at does anyone know?
B). Can you get a thermal cut out switch that resets itself each time? I'd like to wire it in-line to the signal to the relay.
C). Does anyone have an old new gen pump kicking around I can play with/make compatible with the BMW system?
Post #65053 20th May 2011 3:07pm
why not just replace your pump with a newer one..the up/down speed is pretty quick on mine..
Post #65055 20th May 2011 3:09pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I agree, just replace
where we you thinking of putting the secondary pump - thinking about the noise
Post #65070 20th May 2011 3:41pm
dan_uk_1984
I don't need to replace my one, I just want a secondary one. Much like the battery, no need, but want to see what is possible.
Running a second compressor would half the load on the existing one for example and it would live twice as long. Also means there is always a "hot spare".
Might also look at installing a second reservoir as per the BMW system that wasn't carried over to the RR. This then could expand to haiving an air line atatched to be able to inflate ones own tyres.
Think of all the 20p's you'd save!
It's actually something I've wanted to do since having a classic with EAS.
Post #65082 20th May 2011 4:23pm
Havank
where will you fit it?, and how will you connect it up to the ecu, to ensure they work together
Post #65084 20th May 2011 4:36pm
dan_uk_1984
I have LPG, so plenty of space in the spare wheel well... When mounted on the rubber mounts the pump is fairly silent.
The EAS ECU is less trouble than you may think:
It asks for the tank to fill by supplying the compressor with 12V. It looks at the pressure of the tank increasing, when it reaches its threshold it removes the 12V supply.
It has speed logic, but that logic is written to only take account of a slow pump rather than fast.
There are other scenarios, for example if the system detects the pressure switch is faulty, it will raise the suspension using the pump only and not the pressure from the reservoir. Again this wouldn't cause an issue in this setup.
To power the other pump I would use a switched relay, so when the ECU calls for the pump to run, it also switches the relay to the other pump on, when it turns off, the other pump turns off.
D
Post #65089 20th May 2011 4:46pm
wouldn't it be great if you could use the two compressors to make the range bounce like those american custom cars..
Post #65092 20th May 2011 4:56pm
Jsb
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
I have an image of the Mexican low riders in my head if you get the wiring wrong............please video!
Post #65093 20th May 2011 4:58pm
dan_uk_1984
Neutral
Post #65095 20th May 2011 4:59pm
dan's not amused.... Very Happy
Post #65096 20th May 2011 5:00pm
dan_uk_1984
Someone's gotta come up with these daft ideas!
Post #65099 20th May 2011 5:12pm
M44K TS
No 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #65109 20th May 2011 6:31pm
johnson1
The 2011 height changes are insanely quick - sub 5 seconds to select access. Have a look at the latest pump - I'm sure that will suffice!
Post #65110 20th May 2011 6:31pm
I'm liking this idea. I've thought about this but never implemented. You can pic up some very cheap twin stage tyre compressors at a fraction of the cost of a new EAS pump. What pressure does the pump need to deliver? Dan might be worth sending Preston air an email as they are currently working on a compressor upgrade.
Post #65113 20th May 2011 6:48pm
fisha
The P38 pump was rated to 150psi IIRC. The L322 is a similar size / bladder setup. I dont imagine its going to be too much different from that.
An aspect to look into as well is the duty ratio of the pump ( how much time on versus time off ). The pump in the P38 was higher than average ( 15% rings a bell ) ... meaning that it needs to run for longer periods before heating up too much.
Your idea is something I consider as well ... but not something i'll look into beyond an idea until my pump wimps out. V8 or else ...
Post #65199 21st May 2011 9:13pm
