Home > Technical (L322) > Second Compressor Install/Mod |
The Plan:
20th May 2011 3:07pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
why not just replace your pump with a newer one..the up/down speed is pretty quick on mine.. |
20th May 2011 3:09pm |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 |
I agree, just replace
20th May 2011 3:41pm |
I don't need to replace my one, I just want a secondary one. Much like the battery, no need, but want to see what is possible.
20th May 2011 4:23pm |
where will you fit it?, and how will you connect it up to the ecu, to ensure they work together |
20th May 2011 4:36pm |
I have LPG, so plenty of space in the spare wheel well... When mounted on the rubber mounts the pump is fairly silent.
20th May 2011 4:46pm |
wouldn't it be great if you could use the two compressors to make the range bounce like those american custom cars.. |
20th May 2011 4:56pm |
Jsb Member Since: 24 Nov 2010 Location: Southampton Posts: 78 |
I have an image of the Mexican low riders in my head if you get the wiring wrong............please video! |
20th May 2011 4:58pm |
20th May 2011 4:59pm |
dan's not amused.... |
20th May 2011 5:00pm |
Someone's gotta come up with these daft ideas! |
20th May 2011 5:12pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
No 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
20th May 2011 6:31pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I'm liking this idea. I've thought about this but never implemented. You can pic up some very cheap twin stage tyre compressors at a fraction of the cost of a new EAS pump. What pressure does the pump need to deliver? Dan might be worth sending Preston air an email as they are currently working on a compressor upgrade. |
20th May 2011 6:48pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
The P38 pump was rated to 150psi IIRC. The L322 is a similar size / bladder setup. I dont imagine its going to be too much different from that.
21st May 2011 9:13pm |
