Home > Technical (L322) > activate starter code...... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
Found these bits about alarm immobilisation..... just in case it’s the alarm side of things causing issue. Don’t think that would say Code on the dash, but might help diagnosis?
2nd Aug 2021 1:19pm |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Ok ,That's great shall try the activation or deactivation on ignition 1
2nd Aug 2021 2:23pm |
I don’t think RAVE works with the latest updates to Windows 10, even in compatibility mode.
2nd Aug 2021 3:10pm |
Yeah something isn't right , but not that long since I last used it , but maybe after last update.
2nd Aug 2021 4:43pm |
Emergency Deactivation doesnt work on ign 1 either, so probably the reason is countdown doesn't start. |
2nd Aug 2021 6:58pm |
Definitely something strange going on, which is why I’m wondering if it’s ECUs losing comms between each other. Never heard of this before... not helpful I know...
2nd Aug 2021 7:13pm |
Workshop Manual is here to download as a PDF....
2nd Aug 2021 7:18pm |
Bought another Sat Nav and still the same , no countdown! |
9th Aug 2021 6:51pm |
I have put it out there to see if I can find someone locally using Nanocom.
10th Aug 2021 10:49pm |
That sounds like a plan. Can’t help thinking it’s something ECU related rather than sat nav etc. Beyond my knowledge now though I’m afraid.
11th Aug 2021 11:51am |
I need more questions answered.If the Sat nav is required to input a personal code placed by someone in the past , and this code is lost , what is it communicating with , the BCM or the immobiliser. Does the immobiliser when it doesn't recognise the key chip allow the engine to turn but not fire up.
12th Aug 2021 9:09pm |
I think some of that is in the screenshots from the workshop manual.
13th Aug 2021 8:10am |
Thank you , seems logical. |
13th Aug 2021 10:28am |
To add then the EWS may also be involved, does that not sit in the centre console beside the gearstick. |
13th Aug 2021 10:32am |
Just realised that is the Ecu immobiliser , but saying that this has a fixed code only recognised by the key , whereas the code entered each time you want can be anything and forgotten after the car starts.
13th Aug 2021 11:01am |
