Home > Technical (L322) > ZF 5HP24 2002 4.4 V8 173,000 miles
MrfixitRR
United Kingdom 2002 Range Rover Vogue 4.4 V8 Tonga Green
Well I have been having issues with my 4.4 v8 5hp24 gearbox when pulling away I would get a large shunt in the back and when warmed up it would hang in gears longer than it should so I done a fluid change it was slightly better but still not right , so was going to get another box anyway so I thought nothing to lose take the valve block off and inspect it only to find the casting completely cracked off ? Apparently a common problem . Will another valve block solve my issue ? It has also had a lack of engine braking in 1st gear
Post #600523 13th Jul 2021 3:18pm
Gsxr1250dave
Nothing to lose, you pretty much found the reason why you were having issues
Post #600530 13th Jul 2021 4:13pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Have a go Thumbs Up
Post #600533 13th Jul 2021 4:40pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
RRPhil on here is God when it comes to this gearbox in particular. He will be along shortly I am sure. sadly he has retired from the Gearbox business but is still the font of all knowledge.
Post #600552 13th Jul 2021 7:49pm
MrfixitRR
Thanks for the help Cool Well I fitted a secondhand valve block filled with fresh fluid and it drove perfect for about an hour until I got in some slow moving traffic then it was changing up past 2nd no faults were coming up but it seemed like it was in cool down mode stopped let it cool down then it drove fine all the way home . So now I must have a problem with either the gearbox cooler, thermostat or radiator which is it most likely to be ? Is it possible to jet wash the radiator through it will it be completely clogged ?
Post #600579 14th Jul 2021 5:38am
Dolphinboy
The gearbox cooler is fed by the lower part of the radiator IIRC and gets sludged up. A New radiator is your best bet I reckon.
Post #600590 14th Jul 2021 8:08am
Highroller
You could disconnect the Radiator hoses & try flushing the radiator. See what comes out.
Worth having a go before replacing the rad, You've got nothing to lose. Thumbs Up
Post #600595 14th Jul 2021 8:37am
Gsxr1250dave
It's gonna be your rad, there pretty cheap and easy to replace I got mine off the bay you have done the hard work.
Iv got a new spare in my garage not sure how I ended up with 2 but not sure how far you are from me
Post #600669 14th Jul 2021 7:42pm
RRPhil
Just checking, but was your replacement valve body assembly definitely a ‘350’ model (i.e. 1058 127 350)?
Phil
Post #600672 14th Jul 2021 7:58pm
MrfixitRR
Hi Phil
I am not 100% sure it came from a 4.0 Jaguar XK8 , I plan on dropping the sump for another fluid change so I can check then .I have the 2 pics of the replacement valve block from the ebay listing I will put on here
Post #600678 14th Jul 2021 8:24pm
MrfixitRR
Post #600679 14th Jul 2021 8:25pm
Gsxr1250dave
https://www.ebay.co.uk/itm/Aluminum-Radiat...635-2958-0
Better than the original which is plastic, I will proberly fit 1 of these at some point
Post #600705 14th Jul 2021 11:03pm
