Home > Technical (L322) > Td6 gearbox issue, advice needed |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
Easy to do a diy fluid and filter change then add some Dr Tranny to the new fluid. You can always just add the Dr Tranny... Sounds like Torque Converter judder
11th Jul 2021 4:45am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1177 |
The above post would be my first answer. Did it happen just the once? have you tried to re-create the exact situation to see if it does it again? If not, it may be possible that you had a momentary fuel or throttle issue that cleared on kick down when applying more throttle. Maybe wrong, just a thought, if so I would go with the above first, rather than diving straight into a box / TC change / overhaul. At that mileage the box should be OK. Fingers crossed |
11th Jul 2021 1:40pm |
Jonnys19882 Member Since: 01 Jan 2021 Location: Goytre Posts: 53 |
It’s had a very slight judder before but I didn’t think anything of it but know it’s been more prevalent I now know that’s what it was. Is the dr tranny safe to put in? And also is it a temporary fix or more permanent? As the box is still low mileage I want to protect it the best I can and would I be better putting a new TC in?
11th Jul 2021 3:59pm |
Sounds like you do have an issue there, but..........
11th Jul 2021 4:36pm |
Thanks I will do!! |
11th Jul 2021 4:41pm |
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 |
Happened to us . On a 35k ZF HP6 a few months back. First port of call was a diagnostic with Mr Gearbox , Sheffield. Turns out it was caused by dodgy reluctor rings and rear abs sensors.. Sending duff speed signals to the gearbox ecu , especially when it was downshifting.
11th Jul 2021 9:27pm |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 |
you can do a test, put in drive, roll down the window, and let it go, if you hear it crawling, (noise like pads on the iron) it means that the converter is compromised |
17th Jul 2021 6:53am |
