![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Alternator help |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 756 ![]() ![]() |
Sounds like the alternator, easy check is disconnect the alternator and reconnect the battery - there shouldn't be any smoke |
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 ![]() ![]() |
I'm going to have to try and strip it down see if I can get to the alternator. Certain it is the issue with the smoke coming from it
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
If the rectifier fails in the alternator thats exactly what happens if it goes short rather than open circuit. BMW i3 Electric Car
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1233 ![]() ![]() ![]() |
If the alternator bearings are ok, then the belt should also be fine. If the belt is worn, just change that.
Brilliant thanks, cars done 130k so will assess when I get to it
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3819 ![]() ![]() ![]() |
Look in the 2010/12 WM in the Wiki ( free download)
That's absolutely marvelous. Just realised I already had.it downloaded and it's got a wealth of info. Cheers mate |
VogSe Member Since: 21 Jun 2021 Location: Lincolnshire Posts: 12 ![]() ![]() ![]() |
There’s a YouTube video for that, sams motors or something. Think he’s a member on here as well. 61 2012 4.4 TDV8 Vogue SE
