Home > Maintenance & Mods (L322) > 4.4 TDV8 Alternator help
BenRK
Hi all, looking for some clarification
Got in my car before, turned it on and had a charging system fault and restricted performance. Usedy reader to clear all codes before restarting the car, or at least trying to but it now wouldn't turn over.
Started to smell burning and lifted the bonnet, smoke pouring from alternator so I disconnected the battery and slowly the smoke stopped. Now waiting for recovery to get
Me home
Question being, does that sound like normal alternator failure that could be rectified by straightforward replacement or is it likely to be something more than that?
Cheers
Post #600161 9th Jul 2021 4:52pm
cass
Sounds like the alternator, easy check is disconnect the alternator and reconnect the battery - there shouldn't be any smoke
Post #600165 9th Jul 2021 6:30pm
BenRK
I'm going to have to try and strip it down see if I can get to the alternator. Certain it is the issue with the smoke coming from it
Am I right in thinking I will be better off changing idlers / pulleys / belts too?
Post #600203 10th Jul 2021 2:22pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
If the rectifier fails in the alternator thats exactly what happens if it goes short rather than open circuit. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #600211 10th Jul 2021 4:29pm
Merchy
If the alternator bearings are ok, then the belt should also be fine. If the belt is worn, just change that.
I would not automatically change all the other bits just because of the alternator, if all these parts are fine - if it ain't broke, don't fix it. Thumbs Up
Post #600216 10th Jul 2021 5:30pm
BenRK
Brilliant thanks, cars done 130k so will assess when I get to it
I am struggling at the moment to work out the best way to remove the cooling fan shroud, the wiki unfortunately has no pictures anymore so just a case of plodding on and seeing what I can achieve.
Post #600217 10th Jul 2021 5:59pm
Baltic Blue
Look in the 2010/12 WM in the Wiki ( free download)
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #600219 10th Jul 2021 6:23pm
BenRK
That's absolutely marvelous. Just realised I already had.it downloaded and it's got a wealth of info. Cheers mate
Post #600220 10th Jul 2021 6:33pm
VogSe
United Kingdom 2011 Range Rover Vogue SE TDV8 Barolo Black
There’s a YouTube video for that, sams motors or something. Think he’s a member on here as well. 61 2012 4.4 TDV8 Vogue SE
Def and discos of old
Post #600227 10th Jul 2021 8:37pm
