Home > Maintenance & Mods (L322) > Intermittent click on starting
TDV8John
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Good afternoon all
I have recently had a problem where i get a click on starting but not all the time and seems pretty random although i fear it is becoming more frequent.
A quick scan on here suggests starter motor is likely culprit but before i go ahead and get a replacement just wondered if it could be anything else more straightforward as when it does engage starter motor fires up as usual so could it be electrical i.e. dirty contacts somewhere?
Many thanks
Post #599794 6th Jul 2021 1:35pm
dhallworth
I’d put money on that being the starter motor.
Our 2012 is on it’s 3rd replacement (4th in total) at just 24k miles.
It’s a doddle to change from underneath the car, you can do it with removing nothing else but the undertray. I had it off in 30 minutes and was able to get a Denso one from Euro Car Parts that was in stock on the shelf and had it done very quickly. Although it’s not the cheapest thing to change (Circa £350 for a Denso from memory) it’s certainly an easy job to change.
Ours started off intermittently and got progressively worse before it failed altogether so I’d change it before it fails somewhere that it’s a right pain in the arse!
There is a guide on here somewhere about cleaning the contacts on the starter which might be worth doing too. I’ve got the one I took off ours to clean and keep as a spare.
Post #599796 6th Jul 2021 2:03pm
TDV8John
ok great, thanks for the swift reply David I'll order a replacement and get the spanners out! Laughing
I see the Denso one on Euro Parts is approx £550 Shocked so just wondered if anyone on here has any experience of other aftermarket examples? Rimmer Bros has one for £222 inc vat. I don't do that many miles and she only gets used a couple of times a week max.
Thanks again
John.
Post #599797 6th Jul 2021 2:11pm
dhallworth
Unless you use their discount codes the prices are wired to the moon. Add it to your basket then use the code “goal45” and it brings the price down to £366.
Denso were the original make. I’m not sure if there’s any better ones or not.
Post #599802 6th Jul 2021 2:43pm
coopss
I had this. Swapped the starter for a denso one but didn’t cure the issue. Thought it was a bad cable/connection but couldn’t find a fault. Specialist swapped for a genuine one and fine ever since! 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #599832 6th Jul 2021 6:06pm
