![]() | Home > Maintenance & Mods (L322) > Intermittent click on starting |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
I’d put money on that being the starter motor.
TDV8John Member Since: 08 Nov 2015 Location: Kent Posts: 19 ![]() ![]() ![]() |
ok great, thanks for the swift reply David I'll order a replacement and get the spanners out! |
Unless you use their discount codes the prices are wired to the moon. Add it to your basket then use the code “goal45” and it brings the price down to £366.
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I had this. Swapped the starter for a denso one but didn’t cure the issue. Thought it was a bad cable/connection but couldn’t find a fault. Specialist swapped for a genuine one and fine ever since! 1995 4.6 v8, green/tan (long gone)
