Home > Maintenance & Mods (L405) > Facelift rear lights.
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
Just picked up a genuine pair of 2019 rear lights from EBay. One has a broken lens but I’ve also managed to buy a lens cover from Powerful. £403 all in.
I plan to heat up the broken lens with a heat gun, carefully remove the lens and remaining glue and use something like a thin bead of CT1 to fix the new lens.
Parts arrive on Wednesday so I’ll keep the thread updated.
Post #599459 2nd Jul 2021 10:48pm
number76
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
....No updates, how did you get on?. 2014 L405 3.0 V6 Autobiography Santorini Black 49k
Post #644465 1st Oct 2022 8:21am
FF777
Hi
I've done the lens change,
You have to snap off the old lens, you won't be able to loosen it by heating it,
There is a locator groove all the way round the light where the ridge for the lens sits in to, you will have to clean the groove with a dremel as the ridge on the old lens will be broken off in the groove
Lastly bond the lens, try not to tough the silvering in the lens.
Hope this helps
Post #644783 4th Oct 2022 6:44pm
