Home > Technical (L322) > Trans Failsafe Prog P0705 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Could be a seized or seizing gear level selector rod, but this is usually evidenced by not being able to select a gear at all? Perhaps the nut has worked loose? You will need to get under the car and check the selector rod is well lubricated and correctly fitted and adjusted. .
27th Jun 2021 10:23pm |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 190 |
Thanks, I'll check that out. |
27th Jun 2021 10:29pm |
By the way, there's never been any issue or stiffness when moving the gear lever, it's nice and free moving. It just seems to be when I start the car and select reverse to reverse out of my driveway, and it's just the first time on a given day, the rest of the day after it's absolutely fine. However I will still get under and grease it up just in case. |
28th Jun 2021 7:51am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 972 |
Might be worth getting the inhibitor switch apart and giving it a clean
28th Jun 2021 9:16am |
Thanks Phil, I did think that might be on the cards after looking at a load of posts on the forum.
28th Jun 2021 9:19am |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 587 |
Hi. I had the trans failsafe program warning pop up and the car would not start in P or, if it did, it would go into reverse with a thud and show the same message. I found an inhibitor switch at a reasonable price and imported it along with many other things prior Brexit. Turned out it was the battery though. I would first rule out the battery and then look into the inhibitor switch. Stealers here charge €1200 + VAT + labour. Got mine new for a third of that, so worth investing in one, especially if you can source it locally.
28th Jun 2021 3:39pm |
Thanks, I did consider it being the battery as I didn't know how long the old one had been on there for, so I just fitted a new one last week. it's done this twice now since , so guessing it might not have been the battery, either that or I have a power drain somewhere. I have gone back to the car after 10 minutes and can see that the light has gone off next to the "P" by the gear lever so it seems to be going to sleep.
28th Jun 2021 4:00pm |
Assuming you have checked the alternator output and used a proper battery, perhaps you should check the voltage in the morning having left the car parked overnight, in hopes it would be okay.
28th Jun 2021 4:18pm |
So just checking voltages quickly:
28th Jun 2021 5:38pm |
Seems like the alternator is doing its job and that you might be after some drain then...
28th Jun 2021 5:49pm |
I did notice before that when it went into Trans fail I lost the gear display on the dash and also rear camera stopped working. |
28th Jun 2021 9:16pm |
So it's a battery drain / low voltage problem, most likely
29th Jun 2021 4:34am |
Rear wiper works fine, will check headlamp wipers today. |
29th Jun 2021 6:47am |
So this morning I started the car, just drove to work and no issues at all.
29th Jun 2021 9:09am |
