Home > Maintenance & Mods (L322) > How to remove rear lights? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
I need to help my dad replace a broken rear light, how is it removed?
13th Aug 2007 4:20pm |
JayMann Member Since: 25 Mar 2007 Location: here Posts: 59 |
Pop over to RRSport??
21st Nov 2007 9:34am |
matth Member Since: 21 Nov 2007 Location: Dorset Posts: 3 |
Simply lift down the rear tailgate, remove the two screws from the side of the light, that will be easily seen when the tailgate is lowered.
21st Nov 2007 11:28pm |
some brute force got this done in the end, the 2 retaining lugs hold strong, you really do have to be brave. Discovery 4 HSE
20th Dec 2007 9:25am |
Robert_it Member Since: 13 Oct 2008 Location: Bergamo Posts: 27 |
Just removed my R/H rear light the other day (FFRR SC). And yes they do sit very tight in those holders. The upper plastic "insert" is a part of the lamp assembly body but the lower is a loose plastic "clip" which in my case broke when I gently took it off??? It looks like it is designed to break before the lamp itself and I was confident that I could just go to Land Rover and buy another one....
15th Oct 2008 7:38pm |
Robert,
15th Oct 2008 9:06pm |
