![]() | Home > Maintenance & Mods (L322) > How to remove rear lights? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
I need to help my dad replace a broken rear light, how is it removed?
JayMann Member Since: 25 Mar 2007 Location: here Posts: 59 ![]() ![]() ![]() |
Pop over to RRSport??
matth Member Since: 21 Nov 2007 Location: Dorset Posts: 3 ![]() ![]() ![]() |
Simply lift down the rear tailgate, remove the two screws from the side of the light, that will be easily seen when the tailgate is lowered.
some brute force got this done in the end, the 2 retaining lugs hold strong, you really do have to be brave. Discovery 4 HSE
Robert_it Member Since: 13 Oct 2008 Location: Bergamo Posts: 27 ![]() ![]() |
Just removed my R/H rear light the other day (FFRR SC). And yes they do sit very tight in those holders. The upper plastic "insert" is a part of the lamp assembly body but the lower is a loose plastic "clip" which in my case broke when I gently took it off??? It looks like it is designed to break before the lamp itself and I was confident that I could just go to Land Rover and buy another one....
Robert,
