Home > Technical (L322) > ABS ECU and IID Tool (Solved)
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
On a short trip to take SWMBO for her second COVID jab, the 3 amigos put in an unexpected appearance for no apparent reason, with only the standard faults codes seen by the IID Tool:
1. 0x32 CAN bus fault
2. 0x57 Air suspension active/inactive
When I got home I reset the codes and for good measure did a battery reset and steering angle calibration, however on a subsequent journey there was a small grab on one of the front wheels as I slowed for a junction, but no fault codes or indication were seen.
Later in the same journey there was a bigger grab from what seemed to be the OSF, and the 3 warning lights appeared and again only the above faults read off the IID Tool.
With no other faults logged, I'm leaning towards a failed front OSF ABS sensor, but is there any other way of getting more ABS detail from the IID Tool, or am I restricted because its an 04 model?
Cheers David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #597840 17th Jun 2021 6:24pm
crowebeard
Out for a short journey this morning, no faults appeared until I stopped at the end of the journey with the engine running. 2 additional codes appeared this time:
0x52 Yaw rate sensor open circuit
0xB Battery Disconnect Unit 1 (ARM - Airbag)
Tried taking live readings of the 4 wheel/ABS sensors, but all 4 went to NA after setting off, so i'm leaning towards either the ABS ECU or the DSC sensor under the centre console (given the new code) rather than an actual ABS sensor.
The only odd fault is the airbag one.... David
2021 Mazda CX-5
Post #597903 18th Jun 2021 9:52am
crowebeard
After talking to Patrick at GAP, I managed to get the wheel speed readout that showed all 4 ABS sensors working correctly.
IID fault codes:
So bought a used ABS ECU and swapped them over, however new one needed VIN coding before it would work.
IID Tool can't do this so tried all the usual local Land Rover specialists, but no one had either the Testbook/T4 or Autologic equipment that seem to be the only 2 systems that can recode an ABS ECU, not even the main dealers! Shocked
Eventually found the excellent Rob at Winston Pincombe in Chumleigh had Autologic, and after only 15mins with him, job done. All working normally again. Very Happy David
2021 Mazda CX-5
Post #598724 25th Jun 2021 12:37pm
good news David. Thumbs Up ... - .- -.
Post #598726 25th Jun 2021 12:53pm
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
Hi Crowebeard
I have just seen this post and I have almost identical issues to you on my 03 4.4v8.
Can you tell me if once you changed the abs ecu (and prior to the fella in Devon recoding it) whether the faults dispeared (but presumably the abs etc didnt work).
Kind Regards
neil. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #611307 1st Nov 2021 3:56pm
crowebeard
Hi Neil
Yes it did clear the Yaw and CAN bus faults, but the ABS, HDS and inactive suspension lights/faults remained until the unit was recoded. I did try changing the yaw sensor before the ABS ECU, but gave up half way through as it's a bit of a pig to get to.
Hope you get it sorted soon, the brake grabbing is a bit disconcerting to say the least! Laughing
Cheers
David David
2021 Mazda CX-5
Post #611374 2nd Nov 2021 10:51am
pcourtney
crowebeard wrote:
two additional codes appeared this time:
Hi David, thank you for solving this SRS Airbag error - my IID was throwing up the same error on my 2004 4.4 Petrol BMW engine, and the below fix worked for me using GAP IID scanner Smile
https://www.fullfatrr.com/forum/topic52722.html?highlight=srs
Post #702703 20th Oct 2024 3:10pm
