Home > Maintenance & Mods (L322) > ABS Reluctor Ring |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 |
https://www.ebay.co.uk/itm/284105904235?fi...Sw9IZfzPNu 2006 4.2 SC |
16th Jun 2021 6:47pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7793 |
It meant a replacement driveshaft when I had my TD6, but since then, a number of suppliers do them separately. 2011 Range Rover Vogue SE 4.4 TDV8
16th Jun 2021 7:43pm |
Blackbird51 Member Since: 22 Sep 2011 Location: Portadown Posts: 39 |
Thanks for info. The ring that came off is only 2-3mm thick. On checking eBay link I see the item shown is 5mm thick. Internal diameter of new part is 93mm so will be a tight press fit.
16th Jun 2021 10:28pm |
Yes, I believe it’s a tight fit. The rear left stuffed up on mine, and that’s where the speedo feeds from. That’s an issue, as when I tried to drive it, car thought 3 wheels were spinning, as it had a zero speed reading. It activated traction control and then reduced engine power 🤣
17th Jun 2021 8:18am |
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 |
Hi. Happened to me. Got the rings and some Delphi sensors ( try getting OE ones ). Turned out the drive shafts where the rings fit onto were rotten - looked like the rats had chewed them. So 500 a side shafts needed from LR.
19th Jun 2021 1:22pm |
