Home > Maintenance & Mods (L322) > ABS Reluctor Ring
Blackbird51
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
ABS Reluctor Ring
Hi
On removing hub knuckle in order to replace the ball joint cassette I found that the reluctor/sensor ring has come away from the driveshaft. It appears to be very loose on the shaft. the ring itself is not cracked or broken. It seems like it is 2-3mm too big in diameter. Possible parts of it had corroded away?
Does this mean a replacement driveshaft or can anyone advise as to how to reattached it.
Thanks
Post #597728 16th Jun 2021 6:33pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
https://www.ebay.co.uk/itm/284105904235?fi...Sw9IZfzPNu 2006 4.2 SC
Post #597729 16th Jun 2021 6:47pm
mjdronfield
It meant a replacement driveshaft when I had my TD6, but since then, a number of suppliers do them separately. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #597732 16th Jun 2021 7:43pm
Blackbird51
Thanks for info. The ring that came off is only 2-3mm thick. On checking eBay link I see the item shown is 5mm thick. Internal diameter of new part is 93mm so will be a tight press fit.
Obviously time to order new part.
Thanks again.
Post #597745 16th Jun 2021 10:28pm
mjdronfield
Yes, I believe it’s a tight fit. The rear left stuffed up on mine, and that’s where the speedo feeds from. That’s an issue, as when I tried to drive it, car thought 3 wheels were spinning, as it had a zero speed reading. It activated traction control and then reduced engine power 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #597777 17th Jun 2021 8:18am
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi. Happened to me. Got the rings and some Delphi sensors ( try getting OE ones ). Turned out the drive shafts where the rings fit onto were rotten - looked like the rats had chewed them. So 500 a side shafts needed from LR.
Got two from a breaker - in great condition - for 100 the pair off a low mileage 2011 RR. Fitted new boots etc and painted them. Reluctor rings were intact and in good order. A good few hours, and some high end swearing, to fit. Delphi sensors were no good so revived the OE ones that were fitted. Loads of plus gas and patience and I managed to get them out .
That was a few months back. All good since. ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #598027 19th Jun 2021 1:22pm
