Home > Technical (L322) > Air con is blowing warm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Clearly the compressor isnt being called, cycle the aircon or econ button on / off to make sure it's enabled. BMW i3 Electric Car
13th Jun 2021 2:26am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1176 |
https://www.fullfatrr.com/forum/topic59850.html
13th Jun 2021 11:21am |
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 |
I took mine to Kwik Fit today for a re gas and it wasn't holding the pressure so will need to find the leek now. thanks for your advice though |
13th Jun 2021 6:15pm |
Did they not put a dye in it for you? It shows under UV light and makes leaks very easy to spot.
13th Jun 2021 7:24pm |
No they didn't put any dye in dare I say time to take it to a proper garage Ill send to an indy that I use the only reason to use Kwik Fit was if it didn't work it's free. |
13th Jun 2021 7:55pm |
An extra question for this thread, does anyone have any suction / discharge or system pressures taken from a system running in good order, that would be a help when diagnosing faults Thanks Couldn't find any figures on the net, I am used to working on big Air Con / large fridge systems, but not tiny ones on cars |
13th Jun 2021 8:00pm |
Does that not vary with engine revs and temperatures? BMW i3 Electric Car
14th Jun 2021 2:23am |
Yes you will get some variations, but for instance with the car sitting idling on the drive say at 25 degrees ambient temp would give you a datum point as an example of a a system in good order, ball park figures so to speak. |
14th Jun 2021 7:30am |
