Home > Technical (L322) > Fans don't switch off. |
chinkoa Member Since: 17 Jan 2014 Location: West Yorkshire Posts: 34 |
The out of the blue the Fan does not switch off.. Could it be a relay? if so where is it and what colour?
10th Jun 2021 8:04pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
https://fusesdiagram.com/range-rover/fuses...-2012.html
10th Jun 2021 9:52pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
Another common item is the FSR, search on here, lots of info... Pete
10th Jun 2021 10:07pm |
Hi Martin,
10th Jun 2021 10:11pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 368 |
Was FSR that failed on mine that left fans running all the time even with ignition off and vehicle locked...only a flat battery stopped it! Had to use a key as central locking wouldn’t work. Now have a charger for 13 pin electrical socket. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
10th Jun 2021 10:39pm |
Merchy and Haylands,
12th Jun 2021 6:20am |
I think the FSR is more common, get a genuine one, the cheap ones don't last many months and are false economy if your fatty is a keeper.... Pete
12th Jun 2021 9:28am |
I did not realise that the FSR could cause the fans NOT to stop, There was me thinking only about the FSR stopping the fans starting ooooppppssss
12th Jun 2021 10:08am |
FSR can do all sorts, on all the time, off all the time, wrong fan speed and a combination......
12th Jun 2021 12:23pm |
