Home > Technical (L322) > Fans don't switch off.
chinkoa
United Kingdom 2004 Range Rover Vogue Td6 Java Black
The out of the blue the Fan does not switch off.. Could it be a relay? if so where is it and what colour?
Colin Range Rover Classic 1989
Range Rover Vogue 2004
Rebuilt Series 3 1983
Range Rover P38 1997
Series 3 County
Post #597089 10th Jun 2021 8:04pm
Merchy
https://fusesdiagram.com/range-rover/fuses...-2012.html
The above link gives you all the fuse and relay locations for the vehicle.
I am assuming you mean the fan for the heating / air con ?
If so, the control unit has an electrical feed and a fuse to supply the unit as a whole, all functions of that unit are controlled by a built in PCB, so there is not a separate relay for the fan. Either the switch on the unit is faulty or there is a fault in the PCB.
It is relatively easy to remove the unit and you could try cleaning with compressed air and contact cleaner spray, or get a complete used unit, lots around, not too expensive on the net.
Below are two links for removal and / or fix-repair of this unit.
If the fan would not run it could also be a faulty final stage resistor ( Hedgehog ), so this must be ok.
Hope this helps Thumbs Up
Post #597096 10th Jun 2021 9:52pm
Another common item is the FSR, search on here, lots of info... Pete
Post #597099 10th Jun 2021 10:07pm
chinkoa
Hi Martin,
Yes it is the Heating / Air Con.
y?t. Vids look very interesting and I will get into it in the morning. If it is the PCB. What do I call it when looking for one Thanks for getting back.
I will let you know how I get On.
Series 3 County
Post #597100 10th Jun 2021 10:11pm
Merchy
Hi Colin
Unit has several names, HVAC control unit, climate control unit, heater control unit, etc, etc
As for the unit, if the PCB is faulty, from what I have seen just change the whole unit in one go. If it is not a simple fix, repairing the PCB would probably cost more than changing the whole unit, as said try cleaning or tips in the videos first.
By the way, my name is Rob, don't know where the name Martin came from, mind you, I regularly get called a lot worse from some other people Rolling with laughter
Good luck with the faults
Rob
Post #597106 10th Jun 2021 10:33pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Was FSR that failed on mine that left fans running all the time even with ignition off and vehicle locked...only a flat battery stopped it! Had to use a key as central locking wouldn’t work. Now have a charger for 13 pin electrical socket. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #597107 10th Jun 2021 10:39pm
chinkoa
Merchy and Haylands,
Thanks for your suggestions. I took out the Unit and cleaned it all up. But it has made no diference. So have ordered another FSR. Should that not work I will get a replacement unit. As of now the Fuse pull solution is working.
The PCB. looked OK with no signs of any discolouration or any previous repairs so that's why I opted fot the FSR. option first.
Series 3 County
Post #597220 12th Jun 2021 6:20am
I think the FSR is more common, get a genuine one, the cheap ones don't last many months and are false economy if your fatty is a keeper.... Thumbs Up Pete
Post #597234 12th Jun 2021 9:28am
Merchy
I did not realise that the FSR could cause the fans NOT to stop, There was me thinking only about the FSR stopping the fans starting ooooppppssss Embarassed
This site is very useful, as it means muppets like me learn more all the time Thumbs Up
Post #597236 12th Jun 2021 10:08am
FSR can do all sorts, on all the time, off all the time, wrong fan speed and a combination......
Not just a fatty issue either lots of makes suffer from it... Thumbs Up Pete
Post #597245 12th Jun 2021 12:23pm
