![]() | Home > Technical (L322) > IID Tool transmission oil temp |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
I've not used a rolling graph option, but the iiD displayed the digital value fine when I used it for a transmission oil change a while ago. Nothing special to select it.
Bodsy Member Since: 10 Mar 2011 Location: Shropshire Posts: 45 ![]() ![]() |
There’s severaltransmission temps with the same name. Select all three (I think that’s how many) and one of them will give you the value you’re looking for. |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Mine is a zf6 hp26 trans. I can get menu but when I select view on trans temp I get N/A displayed. |
tommo10ferrets Member Since: 29 Apr 2020 Location: leicestershire Posts: 56 ![]() ![]() ![]() |
Mine shows engine oil temp & trans oil temp on the same list /option, under live values.
Hi as advised by Gap diagnostics I have updated tool to latest firmware but still getting N/A in 6 seed trans temperature. I use the quick list and select trans temp live value and it just sais N/A. Really want this to work can anyone help please |
