Home > Maintenance & Mods (L322) > Restricted Performance Limp Mode, but no codes |
MTG2020 Member Since: 24 Feb 2020 Location: Caerphilly Posts: 35 |
Sorry, forgot quote the vehicle: - 2011 4.4TDV8 Ab. |
5th Jun 2021 12:08pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Soak with Plus Gas, WD40 is rubbish as a penetrating fluid. There are others, just not WD40. BMW i3 Electric Car
5th Jun 2021 3:08pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
Instead of WD40, there are several other products that may be useful to you, see the below link, similar stuff is available at Euro car parts and other stores
5th Jun 2021 3:29pm |
paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44 |
MTG , is the sensor you are attempting to remove on the right hand exhaust manifold as you look at the front of the engine ? .
5th Jun 2021 9:14pm |
Hi Paul. Yes it is. I thought if there was an issue with the Throttle Body, it would throw up a DTC code?
5th Jun 2021 9:43pm |
I replaced my throttle body and it cured it . I also had that sensor replaced because i wanted to get rid of P040D code at a much later date . I ran with that duff sensor for 2 years without issue but OCD got me in the end !!.
7th Jun 2021 2:43pm |
Cheers Paul. Access to the heat shield bolts for the sensor is not progressing as well as I would like...
7th Jun 2021 3:40pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Did you have issues with DPF filling up that a new throttle body cured? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
30th Jun 2021 7:38pm |
The Thottle Body chang made no difference at all. I am still trying to get the EGT sensor out. Hopefully once complete, I can carry out a Forced Regen of the DPF and my problem will be over. ? |
4th Jul 2021 8:36pm |
I'm really sorry you had no luck after changing the throttle body . I didn't have any dpf issues just restricted performance . As I said changing the body cured it .
5th Jul 2021 8:35pm |
I have already changed all these parts. See link.
5th Jul 2021 9:42pm |
