![]() | Home > Maintenance & Mods (L322) > Advice please - bush replacement |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
My car feels unsettled when on anything but smooth surfaces. I’ve had the rear sub frame bushes replaced by the garage I bought the car from which improved things for me, but not quite right still.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
See here for what is involved:
That is an excellent write up Joe90! Kudos |
Yes, if I remember correctly, this is possible, once you remove the inner wheelarches you will find the valve block. You should release the air pressure there. There was an RSW Solutions video on youtube that showed this method, I can't find it now. I think I have something in my gallery also....found it... https://www.fullfatrr.com/gallery/displayi...amp;pos=18 note this is for the front valve block, but the rear is a similar approach. Make sure car is unlocked and keys outside the car before battery disconnection. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Appreciate your responses Joe90.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
My 2p would be to buy genuine bushes or arms if you don't want to do the job again in a few months.... |
Agreed! Genuine all the way!!! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
When the rear subframe bushes were replaced the car had a 4 wheel alignment done.
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
In this thread you will see a list of the suspension parts I replaced, it will give you an idea. (ignore non-suspension stuff).
Thank you RichM63 for that link. Very useful indeed… especially I am currently writing a list of the things I need and their costs!
gravitylover Member Since: 08 Nov 2020 Location: Southeast NY Posts: 36 ![]() ![]() ![]() |
'm pretty sure I have a few bad bushings in the rear of my 06 but just replacing the shocks made a HUGE difference. Less than 2 hours worth of work and it's like a different car. |
Thanks gravitylover.
So I am finally at the point of ordering the new bushes, bars, etc ready to get this job done. It’s been a challenging few months financially due to life getting in the way… but nearly there.
I’ll be following the excellent posts by Joe90 and Fisha… and intend to tackle the rusty areas on the subframe and arms being refitted.
