![]() | Home > Maintenance & Mods (L322) > Advice please - bush replacement |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Cheers for that link. I’ve seen it (although its been a while) along with a few others, and will watch them again once the parts arrive. Always good to watch to familiarise yourself before starting on a job like that. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
I made a start to the job or replacing bushes yesterday, and it didn’t go too smoothly… and not much progress has been made.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I see you have a jack under the hub. I recently did this job on mine and had no issues getting the bolt out, I did not have the jack pushing up on the hub
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
Just from your pictures it looks like you have the hub assy hanging down. ie weight on that bolt.
Thanks RichM63 and wayneg for your posts.
No luck with the freeze spray.
That’s now the LHS all done! After that top hub bush was removed the rest was relatively straight forward |
I started the RHS last night too and am pleased to say that all but one of the nuts and bolts have loosened and are not rusted in. The upper arm and top hub bush is out and have started on the clean up of the subframe before painting it.
And I’m done!
A big THANK YOU to Joe90 and Fisha for their excellent posts on how to do this. And also to all those posting anything helpful on the subject!
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1272 ![]() ![]() ![]() |
Can I ask if you bought the cheaper priced lower suspension arms or some more expensive ones? I've seen a vast difference in price. Just wondered about the quality of the bushes fitted in them. Thanks Kev. |
I intended to buy the genuine bushes only, but ended up buying the upper arm as it was cheaper than buying just the bushes.
