Home > Technical (L405) > 5.0 SC revs to 2000rpm on startup
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
Is this normal? 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
2000 P38, Gen3s, 2 inch lift, KM2s 285/75/16
Post #595701 29th May 2021 12:24am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Mine does initially, then revs around 1500 for a high idle until settling into a sub 1000 when warmed up a little. I always let it settle to a low idle before driving away. Typically only happens when cold.
Seems normal to me. Let it hit operating temp and then mash the go pedal for that supercharger whine!
Post #595702 29th May 2021 2:07am
Hammer
I hate it, any way of stopping that happening? Can’t be good for the motor. 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #595704 29th May 2021 2:33am
CS
Mine does that, I think it's normal and don't worry it will damage the engine. Only Range Rovers since 1988
Post #595731 29th May 2021 10:01am
Mine is the same, no issues doing it, oil pressure is instantaneous on modern engines, no need to let it settle or warm up, just drive away.. Thumbs Up Pete
Post #595749 29th May 2021 2:32pm
knwatkins
It's probably done to warm the engine up quicker. Just an assumption. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #595753 29th May 2021 3:16pm
It only does it for a second, don't think it will have much effect on warm up... It holds the lower gears longer when cold to help with warm up...
It revs up because the injectors use more fuel to aid starting faster, if the throttle didn't open to increase the speed to suit the amount of fuel used then the engine would run rich, the extra fuel could wash the bores of their oil coating wearing the engine... Thumbs Up Pete
Post #595763 29th May 2021 4:34pm
knwatkins
Makes sense Thumbs Up Kev
Post #595767 29th May 2021 5:15pm
Hammer
Thank you 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #595819 30th May 2021 8:35am
goddo
My mechanical sympathy says that 5000 rpm sounds a very high rev for initial start up. Despite the previous "claim" that modern engines have instantaneous oil pressure. Bare or dry metal bearings on a crankshaft is not good at that engine speed. Recipe for serious engine damage in my opinion.
Post #595944 31st May 2021 11:26am
It's 2000, not 5000, sometimes you just have to believe that the guys who design these engines know what they are talking about, the 5.0 S/C is a Ford engine, it's used by Ford Jaguar and Land Rover, they will do mega miles with little to no problems and certainly don't wear out bearings any faster than any other engine...
If they recon the oil pressure can get there quick enough then that's fine with me.. Thumbs Up Pete
Post #595961 31st May 2021 3:06pm
goddo
"It's 2000, not 5000 ,,,,,,"
My apologies. My bad typing.
Post #596055 1st Jun 2021 8:06am
