![]() | Home > Technical (L405) > 5.0 SC revs to 2000rpm on startup |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
Mine does initially, then revs around 1500 for a high idle until settling into a sub 1000 when warmed up a little. I always let it settle to a low idle before driving away. Typically only happens when cold.
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
I hate it, any way of stopping that happening? Can’t be good for the motor. 2015 AB 5.0 Supercharged
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1394 ![]() ![]() ![]() |
Mine does that, I think it's normal and don't worry it will damage the engine. Only Range Rovers since 1988 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Mine is the same, no issues doing it, oil pressure is instantaneous on modern engines, no need to let it settle or warm up, just drive away.. |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
It's probably done to warm the engine up quicker. Just an assumption. Kev
It only does it for a second, don't think it will have much effect on warm up... It holds the lower gears longer when cold to help with warm up...
Makes sense |
Thank you 2015 AB 5.0 Supercharged
goddo Member Since: 27 Oct 2020 Location: south Posts: 83 ![]() ![]() |
My mechanical sympathy says that 5000 rpm sounds a very high rev for initial start up. Despite the previous "claim" that modern engines have instantaneous oil pressure. Bare or dry metal bearings on a crankshaft is not good at that engine speed. Recipe for serious engine damage in my opinion. |
It's 2000, not 5000, sometimes you just have to believe that the guys who design these engines know what they are talking about, the 5.0 S/C is a Ford engine, it's used by Ford Jaguar and Land Rover, they will do mega miles with little to no problems and certainly don't wear out bearings any faster than any other engine...
"It's 2000, not 5000 ,,,,,,"
