Home > Maintenance & Mods (L322) > What is the actual diesel MPG? (2012 4.4 TDV8)
Range Rover L322
The dashboard reads 24-29mpg. I reset it from time to time.
But... calculating it backwards from the pump:
Filled to brim 12th April. Mileage 35567
Filled to brim 17th May. Mileage 35812. = 245 miles. £90.42 = 12.75 gallons (£7.09/gallon) = 19.2mpg
Filled to brim 26th May. Mileage 36090. = 278 miles. £92.95 = 13.11 gallons (£7.09/gallon) = 21.2mpg
Shocked
Anyone have any ideas?
Post #595076 23rd May 2021 1:10pm
MonkeyMan
V Power diesel here is about £7.02 a gallon, which would put you at 18 mpg. That’s 10% better for you….
Post #595092 23rd May 2021 3:45pm
mjdronfield
That sounds really low to me. I don’t check mine, mainly as I can’t figure out the over complicated 3 averages thing that the computer does.
Should be doing about 30mpg on the combined cycle. So would expect more than that.
But... as I say... I don’t know my real figures, so I might be talking rubbish....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #595096 23rd May 2021 4:14pm
coopss
Yeah that’s low! I recently posted about getting 400 miles to a tank which I thought was low - many posts on here averaging 30ish 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #595098 23rd May 2021 4:26pm
Range Rover L322
thank you! that's really helpful. I will adjust my post.
Post #595106 23rd May 2021 6:02pm
V8 Bob
I’m averaging about 25mpg but short trips circa 8 to 10 miles that’s on normal unleaded generally BP. Not helped by hills around here....main use involves a 3/4 mile long drag as soon as I start.
Give a decent run will do low 30’s.
Those are actual litres of fuel and milometer so not trip consumption 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #595111 23rd May 2021 7:21pm
MonkeyMan
If it helps, on my l405 4.4 diesel, if I do motorway driving at 60mph I get about 24-26mpg. If I do motorways at 80 I get 33mpg. My car wants me to have fun….
But also, what’s your cruising speed on motorways, and does changing it affect your consumption up or down?
Post #595115 23rd May 2021 8:27pm
mjdronfield
Not sure it gets in to top gear at 60mph.... wonder if changing up manually on paddles helps with mpg...?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #595120 23rd May 2021 8:52pm
MonkeyMan
That would explain my mystery consumption, and I will try the paddles next time I feel like a leisurely (or hungover) motorway ride
Post #595121 23rd May 2021 9:06pm
jackie-o
Netherlands
Car usually says around 30 mpg but filling brim to brim shows real world consumption is between 25 and 28 mpg.
I have a faulty fuel gauge so try too keep track between fill ups.... RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #595144 24th May 2021 8:08am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Calculated over 70,000 miles I averaged 17.14 mpg but a lot of that was towing 2000 kg of caravan.
Ian
Post #595146 24th May 2021 8:18am
Rob99
19mpg sounds way too low for the 4.4TDV8 engine, assuming it's not in Sport mode and you're not driving it like you stole it Shocked
My 2012 4.4TDV8 Westie used to average around 28mpg on supermarket diesel. Longer motorway runs around 30mpg.
Although not done much mileage in my newer AB, round town I seem to get about 30mpg. Just worked it out for yesterdays 300 mile motorway trip and it was 33mpg Thumbs Up
. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #595153 24th May 2021 9:24am
Martin2
I have an L405, so not exactly the same, but over 11,000 miles I've averaged 27.8mpg. That's calculated, the computer is just over 7% optimistic. I do quite a lot of decent length journeys, if all I did was potter around town it wouldn't be much above 20mpg. Best brim-brim has been 31.1mpg and I have seen around 35-36mpg on the computer on long motorway journeys which would have been around 33mpg.
I don't worry about fuel consumption or even cost too much (I used to run a petrol V8 doing over 30k miles a year), but I do like to keep records...for some reason. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #595155 24th May 2021 9:50am
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
That does seem low fuel economy...
My 2012 4.4 TDV8 (62.000-miles clocked) L322 usually does around 460-480 miles per nearly full tank, but would push into the 500s (I recall getting 520 or more on miles of fuel remaining doing UK general touring when I first got her at 52,000-miles - until the Thatched Garage changed the battery and I lost that good fuel consumption for some bizarre reason) when I first purchased her, which I though was terrific for a full tank costing around £120 back then.
So is it generally good to maintain a 1/4-full tank at all times to keep the DPF in happy times?
Also are those Environmental + DPF additives worth using from time to time? Or do the V-type fuels already have these?
Post #595156 24th May 2021 9:55am
like Rob i was getting high 20's around town and low 30's on runs with my westie..
my L405 tdv6 gets high 30's around town and low 40's on runs...best was 47.7mpg! ... - .- -.
Post #595158 24th May 2021 10:00am
