![]() | Home > Maintenance & Mods (L322) > What is the actual diesel MPG? (2012 4.4 TDV8) |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
V Power diesel here is about £7.02 a gallon, which would put you at 18 mpg. That’s 10% better for you…. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
That sounds really low to me. I don’t check mine, mainly as I can’t figure out the over complicated 3 averages thing that the computer does.
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Yeah that’s low! I recently posted about getting 400 miles to a tank which I thought was low - many posts on here averaging 30ish 1995 4.6 v8, green/tan (long gone)
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
. thank you! that's really helpful. I will adjust my post. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 375 ![]() ![]() ![]() |
I’m averaging about 25mpg but short trips circa 8 to 10 miles that’s on normal unleaded generally BP. Not helped by hills around here....main use involves a 3/4 mile long drag as soon as I start.
If it helps, on my l405 4.4 diesel, if I do motorway driving at 60mph I get about 24-26mpg. If I do motorways at 80 I get 33mpg. My car wants me to have fun….
Not sure it gets in to top gear at 60mph.... wonder if changing up manually on paddles helps with mpg...?
That would explain my mystery consumption, and I will try the paddles next time I feel like a leisurely (or hungover) motorway ride |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Car usually says around 30 mpg but filling brim to brim shows real world consumption is between 25 and 28 mpg.
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Calculated over 70,000 miles I averaged 17.14 mpg but a lot of that was towing 2000 kg of caravan.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1465 ![]() ![]() |
19mpg sounds way too low for the 4.4TDV8 engine, assuming it's not in Sport mode and you're not driving it like you stole it |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 801 ![]() ![]() |
I have an L405, so not exactly the same, but over 11,000 miles I've averaged 27.8mpg. That's calculated, the computer is just over 7% optimistic. I do quite a lot of decent length journeys, if all I did was potter around town it wouldn't be much above 20mpg. Best brim-brim has been 31.1mpg and I have seen around 35-36mpg on the computer on long motorway journeys which would have been around 33mpg.
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
That does seem low fuel economy...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
like Rob i was getting high 20's around town and low 30's on runs with my westie..
