Home > Technical (L322) > Advise please
Jmagg73
United States 2011 Range Rover HSE 4.4 V8 Stornoway Grey
Advise please
2011 Hse 137k
Check engine light comes on very close to home. No message on display. I have no ID tool. Was running the A/C on full blast and just filled the tank with gas. Engine sounds fine otherwise.
Dealership is 45 miles away. Should I risk driving it or have it towed?
Post #595041 22nd May 2021 8:48pm
Does the light stay on if you re-start ?
Sometimes it's just a glitch that goes away (hopefully). If it stays on, then you will need some sort of code reader to figure out what's triggering it.
Post #595054 23rd May 2021 7:04am
Jmagg73
Yea stays on. Even after letting it cool down. Will be calling a tow just to be safe.
Post #595079 23rd May 2021 12:29pm
Jmagg73
Ok this morning the light is off. It must have been too hot. What could be the causes?
Post #595104 23rd May 2021 4:47pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
This won't help you right now but I would recommend getting an OBDII reader. As you've seen on this forum, we really like the Gap Diagnostics IID. If you don't want to spend that much you can buy this $20 reader from Amazon that will read all of the "P" codes. I have this one and it will read codes that cause the Check Engine Light on all brands/models.
https://www.amazon.com/Autel-MaxiScan-MS30...001LHVOVK/
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #595230 24th May 2021 7:21pm
