Home > General (L460 2022) > New 22MY FFRR due to be unveiled next week! |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 |
I might be wrong, but I'm pretty sure that the "Autobiography" name did get something of a break from all early L322 models (2002 to 2009).
31st Oct 2021 8:08pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
Does the new defender not have an option to remote start? I’m sure the Powerful UK petrol model has that. |
31st Oct 2021 8:45pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2586 |
Autobiography started in 1993. |
31st Oct 2021 9:22pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 923 |
My Defender has both on the P400. However the FBH was a cost option and can’t be controlled with the app (just the separate fob). The engine can be started with your phone. |
1st Nov 2021 7:24am |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 |
Mine is exactly the same (FBH with the Fob, remote start to heat or cool through the app) MY23 Panamera E-Hybrid
1st Nov 2021 8:05am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7967 |
Autobiography used to have a different meaning. I'm not sure when it became a trim level / options package. It used to meant some sort of special order, so even if you ordered the base of base models & has special paint, then it was badged AB. A mate of mine had a 2003 AB because he wanted black paint and a black interior and that wasn't an option at the time. I can't remember whether it was just in combination or whether one of them wasn't available as standard. Last edited by Alistair on 1st Nov 2021 8:23am. Edited 1 time in total |
1st Nov 2021 8:21am |
Would be great if the FBH can finally be controlled from the app too. I can’t see any benefit on a cold day from starting the engine rather than the FBH.
1st Nov 2021 8:23am |
Thank you all for the correct info regarding the FBH.
1st Nov 2021 8:34am |
I'm fairly sure that letting your car idle to warm up for 10mins isn't the right thing to do, not with a modern vehicle that doesn't need the carbs warming through anyway. Better to let it warm up more quickly by driving it, but doing so gently until it is up to temperature. MY23 Panamera E-Hybrid
1st Nov 2021 8:51am |
You might be right Martin - I suspect technology in this respect has probably moved on, unlike me |
1st Nov 2021 8:55am |
Sounds like it!
That's actually really good to know, thanks Martin |
1st Nov 2021 9:03am |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 787 |
I had a MY16 AB with the FBH and you could control it via the App and fob. You couldn’t switch on the engine remotely at that time.
1st Nov 2021 9:06am |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 909 |
The Remote App for my car has a "Target Temperature" which you set, it then starts the engine for 30 mins max. All LR cars from 1984
1st Nov 2021 9:45am |
