Home > Technical (L322) > L322 tdv8 My11 Battery drain |
harleyman Member Since: 04 Feb 2021 Location: Madrid Posts: 73 |
Hi,
27th Jul 2021 10:58am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
R1 in the original post is for the accessory sockets. |
27th Jul 2021 11:22am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7788 |
The accessory sockets should not be live once the vehicle has “gone to sleep”, at least on the 2011 car that the original poster has.
27th Jul 2021 11:27am |
The accessory relay powered would be an indicator that the vehicle hasn't gone to sleep rather than a cause. Stuck contacts wouldn't power the relay's coil. |
27th Jul 2021 9:06pm |
Thank you, It seems that my car drains battery for any other reason as the auxiliar power socket power off
29th Jul 2021 9:48am |
I have in mind that the blue-tooth module has sometimes been the culprit. |
29th Jul 2021 10:41am |
Thank you,
29th Jul 2021 11:26am |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Harleyman, the Blutooth phone modules will give exactly the symptoms you are describing. Pull the fibre optic plug connector out the back of the unit, dismantle the plug connector so the two wires are free to move independently. Then get a Bic pen, remove the innards the cut the remaining clear plastic tube of the pen to about 3" long, insert one of the cables in each end so they are facing each other within the tube of the pen but not touching, then wrap the whole thing in black electrical tape.
30th Jul 2021 3:50pm |
Thank you Sam,
30th Jul 2021 5:38pm |
A phone call in progress when the ignition is switched off isn't disconnected, at least for some time but perhaps whilst ever the call continues which suggests that a fault with the telephone module could keep the some of the electrics awake even though the phone isn't in use.
30th Jul 2021 8:45pm |
Hello Harleyman, yes that's issue, all the time the car is running everything else will work fine. What tends to happens is you can sometimes get water ingress into the left hand rear control module compartment. As the phone module is mounted on top of all the others that tends to be the one that gets it first.
31st Jul 2021 9:55am |
Thank you,
2nd Aug 2021 7:41am |
No problem with phone support on my MY12.
2nd Aug 2021 11:32am |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
I have a feeling my CCF is not right, how do I find the default for my car?
9th Aug 2021 9:10pm |
