Home > Technical (L322) > Had a bit of an accident
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Had a bit of a mare this afternoon chaps, basically got the front of the FF up on a couple of axle stands, when one breaks, resulting in the car sitting on its discs.
To cut a long story, rather short, she’s now back on all four wheels, but refuses to start !!!
Tried jump start, nothing!!
The only thing I can think of is, the axle stand on the drivers side ended up stuck up the engine, if that makes sense, and I’m wondering if it’s damaged any wiring.
Any one got an ideas Big Cry
Post #594032 12th May 2021 5:07pm
Won't turn over, or won't start...?
Could be damaged wiring... ripped off the earth lead to the engine..?
I think they have a cut off in case of an accident which might have tripped in, not sure how to reset it on your model...
Worth a check... Pete
Post #594036 12th May 2021 5:20pm
Wogger
Won’t turn over mate, lights on dash, but nothing if I press starter !!
I’m wondering if the jolt of it falling has triggered something !!
Post #594042 12th May 2021 5:44pm
Wogger
Just took the under tray off, axle stand has put a big dent in starter motor, expensive lesson learned me thinks Embarassed
Post #594046 12th May 2021 6:06pm
That's probably it then... Thumbs Up Pete
Post #594047 12th May 2021 6:21pm
What type of axle stand broke? Make, loading ? Image ? .
Post #594049 12th May 2021 6:29pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I used some Halfords 2t axle stands the other year to do a job on my old L322 and noticed straight away that the foot of one of them started to splay. very quickly put it back on the ground and bought some 3t stands. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #594105 13th May 2021 9:22am
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
Frightening.
I have a couple of 6 ton stands. Always go over the top.
I guess a few valuable lessons here, we shove them in the corner of the garage not giving a second thought about using them. An annual inspection must be a good idea?
Just FYI i always leave the jack in place and if the wheels are off, push them under the car, out of the way but also might give some level of clearance should the worst happen.
Wouldn't save the starter motor or anything else but may just save you??
Post #594106 13th May 2021 9:32am
mandelbug
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Sticking wheels under the car is a trick rally drivers use, suspect a few have had their car fall of the quick jack on rough terrain in a welsh forest!
I must admit, I now religiously put the wheels under the car when jacking etc. I had a focus come off the stands when it sunk in to tarmac, stand went underneath and punctured fuel tank. Was scary to say least.
Post #594113 13th May 2021 10:16am
Wogger
I think the ground we were on had something to do with it, the stand sank into the concrete, causing the fall.
The stands were rated 3 ton, and I’d used them before with no problem.
Lesson learnt !!
I was giving the old girl a spruce up, powder coat wheels, new set of rubber (AT3s)
Sort paint bubbling on upper tailgate , fresh set of mud flaps, and a few minor bits of bling.
Post #594121 13th May 2021 10:49am
so lucky that you wernt underneath it at the time...hope you sort it soon. Thumbs Up ... - .- -.
Post #594123 13th May 2021 10:52am
Mr Tee
Aye Stan, that's exactly what scares the bejesus out of me when using stands & jacks etc. Like the time i was changing a wheel, lowered the car, hadn't put the handbrake on , cue the car rolling towards the garage ( my drive is on a slight slope) I panicked, and thankfully I still had my long half inch bar on the last nut, which jammed into the drive , stopping the whole car .... could have been worse.. Shocked
Post #594124 13th May 2021 11:06am
Snowy90 L322
I have always thought these plastic ramps seem a good idea for non wheel related work, but havent had any experience with them and they seem a bit low.
These sort of things, anyone had experience with them or know of any taller ones?
Post #594125 13th May 2021 11:06am
Snowy90 L322
Post #594126 13th May 2021 11:06am
Merchy
As I jack mine up on tarmac, I always put substantial pieces of hard timber under the trolley jack and axle stands, to spread the load. Also where one axle stand would do, I always use two, belt and braces style, so to speak Thumbs Up
Post #594127 13th May 2021 11:16am
