Home > Technical (L322) > 7 pin to 13 pin trailer socket |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 |
You can buy an adapter, failing that it is not hard to just change the socket on the car. 2013 Range Rover Autobiography 4.4 SDV8
11th May 2021 9:26pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 361 |
Attached will fit a 2004 is that correct? Cheapest option is rewiring 7 pin to 13 pin and adding new live feed and splitting earths which are main differences
11th May 2021 10:14pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 229 |
As currently you only have the single 7 pin socket if you want the 13 pin socket to be fully functional the easiest option is either the kit linked to above or the Landrover loom, part no. YWJ500460. |
12th May 2021 8:11am |
bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 144 |
Sorry to butt in - I have two 7 pins (one black and one white) is an adapter available for that or am I better off having them removed and installing a proper 13 pin?
12th May 2021 1:05pm |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 288 |
this is what you need
12th May 2021 1:52pm |
Ivan,
12th May 2021 1:55pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
A 13 pin car socket covers all combinations and I use one of these for my trailer.
12th May 2021 2:47pm |
That's a 13 Pin to 7 Pin adaptor. The OP wanted 7 pin to 13 pin adaptor 2013 Vogue SE SDV8
12th May 2021 2:50pm |
I read him as having one 7 pin socket, but if I'm wrong sorry. Cheers
12th May 2021 2:53pm |
hbthepilot Member Since: 21 Mar 2021 Location: Bludenz Posts: 33 |
Thank you for the reply's! will have a look where I can source a 13 cable YWJ500460!
12th May 2021 3:59pm |
seems like YWJ500460 is from 2006 onwards... anyone has the right part number for a 2004 l322?
12th May 2021 4:31pm |
Does the Westfalia kit fit?
20th May 2021 5:31am |
