Home > Technical (L322) > 7 pin to 13 pin trailer socket
hbthepilot
Austria 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Good evening,
I have a genuine 7 pin socket (Land Rover/Westfalia) installed.
However, I would like to go to a 13 pin trailer socket.
Ang ideas or part numbers?
BR
Post #593926 11th May 2021 9:59pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
You can buy an adapter, failing that it is not hard to just change the socket on the car. 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #593929 11th May 2021 10:26pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Attached will fit a 2004 is that correct? Cheapest option is rewiring 7 pin to 13 pin and adding new live feed and splitting earths which are main differences
https://www.pfjones.co.uk/land-rover-range...506pf.html
https://www.towbarandtrailercentre.com/wiring-diagrams 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #593932 11th May 2021 11:14pm
Fifth Horseman
As currently you only have the single 7 pin socket if you want the 13 pin socket to be fully functional the easiest option is either the kit linked to above or the Landrover loom, part no. YWJ500460.
Post #593952 12th May 2021 9:11am
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
Sorry to butt in - I have two 7 pins (one black and one white) is an adapter available for that or am I better off having them removed and installing a proper 13 pin?
I'm looking at getting a Thule bike carrier which I think comes with its own light board so will need to use them - also would like to get one of Martin's CTEK adapters to keep the battery in good health... 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #593991 12th May 2021 2:05pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
this is what you need
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #593999 12th May 2021 2:52pm
bluebottle
Ivan,
Thank you - that seems the sensible way to solve the issue. Then I can just get one of Martin's 7 pin charging harnesses for when it's sitting in the garage doing nothing for weeks...
Cheers Thumbs Up 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #594001 12th May 2021 2:55pm
rjff
A 13 pin car socket covers all combinations and I use one of these for my trailer.
https://www.ebay.co.uk/itm/13-Pin-to-Twin-...2726715590
A little more expensive but no cable and fits in the tow bar storeage. Cheers
Richard
Gap IIDBT
Post #594007 12th May 2021 3:47pm
IGP
That's a 13 Pin to 7 Pin adaptor. The OP wanted 7 pin to 13 pin adaptor 2013 Vogue SE SDV8
Post #594008 12th May 2021 3:50pm
rjff
I read him as having one 7 pin socket, but if I'm wrong sorry. Cheers
Richard
Gap IIDBT
Post #594009 12th May 2021 3:53pm
hbthepilot
Thank you for the reply's! will have a look where I can source a 13 cable YWJ500460!
BR
Post #594016 12th May 2021 4:59pm
hbthepilot
seems like YWJ500460 is from 2006 onwards... anyone has the right part number for a 2004 l322?
Thank you
Post #594018 12th May 2021 5:31pm
hbthepilot
Does the Westfalia kit fit?
BR
Post #594777 20th May 2021 6:31am
