Home > Technical (L322) > TPMS Valves
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
TPMS Valves
After two faultless weeks in my ownership, woke up this morning to a flat nsf tyre. Soapy water investigation after reinflation revealed the tpms valve to be blowing bubbles. Some judicious poking and prodding of the valve seat stem seems to have it seating correctly and holding pressure.
However I don't want to risk this happening again, so is it possible to replace just the shraeder section of the valve unit? it looks although this section can be unscrewed? Either that or remove the tpms unit completely and replace with old style rubber valve stems (assuming they will fit).
TPMS has previously been disabled, so looking for the most cost effective option.
Thanks in advance for any advice.
 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #593711 9th May 2021 5:05pm
If your TPMS has already been disabled, then you can just replace with rubber valves.
I did that on my old car - those valves are very prone to corrosion & failure - I was glad to see the back of them.
Any tyre place can just remove the TPMS ones & pop some standard rubber valves in.
Post #593714 9th May 2021 5:45pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
You used to be able to unscrew just the valve (most tyre shops do this to let the air out) is it not possible to just replace this? 2011 TDV8 Vogue SE
Post #593746 10th May 2021 7:03am
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
This is just a WAG (Wild A$$ Guess) but it does appear that there's a fair bit of corrosion on the top of your valve stem. I've always been in the habit of keeping a cap on my valve stems.
I even bought a set of these for my RR: https://rimmerbros.com/Item--i-LR027663
Would keeping a cap on the stem help to prevent the valve insert from deteriorating and if there was a small leak, maybe even hold in some air?
I do remember on my old Honda Pilot that the valve on one side of the AC system was leaking but my tech didn't notice this until he removed the cap. It was a very small leak but he caught a slight whiff of the Freon. It was the cap that was preventing it from leaking or at least slowing it down.
Of course, this won't help you now but maybe could be cheap insurance for the future.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #593788 10th May 2021 3:31pm
RR2B
Yes, I always keep the cap on - only removed for the photo shoot! The thread is actually quite worn, to the extent that the plastic cap thread barely catches. Not sure if this is due to corrosion or possibly a non-compatible metal cap being used sometime in the distant past. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #593798 10th May 2021 5:19pm
They corrode, badly.
I had one snap when I was trying to remove the plastic cap - that's when they got binned and I returned to rubber. The later valves on the L405 seem to be more robust.
Post #593802 10th May 2021 6:07pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
If TPMS is disabled, then get them replaced with rubber ones as soon as. They have been know to break and if they crack ot break when driving you don't want to end up wrecking a tyre or alloy.
fist thing I did when I got an IID tool was to turn off TPMS and replace the valves with rubber ones 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #593827 10th May 2021 8:44pm
RR2B
Thanks everyone for your replies and advice. All replaced with old style valves today. One less thing to be paranoid about! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #593901 11th May 2021 5:25pm
