Home > Technical (L322) > TPMS Valves |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7950 |
If your TPMS has already been disabled, then you can just replace with rubber valves.
9th May 2021 5:45pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
You used to be able to unscrew just the valve (most tyre shops do this to let the air out) is it not possible to just replace this? 2011 TDV8 Vogue SE |
10th May 2021 7:03am |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 |
This is just a WAG (Wild A$$ Guess) but it does appear that there's a fair bit of corrosion on the top of your valve stem. I've always been in the habit of keeping a cap on my valve stems.
10th May 2021 3:31pm |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 252 |
Yes, I always keep the cap on - only removed for the photo shoot! The thread is actually quite worn, to the extent that the plastic cap thread barely catches. Not sure if this is due to corrosion or possibly a non-compatible metal cap being used sometime in the distant past. 2011MY 4.4TDV8 Autobiography Baltic Blue
10th May 2021 5:19pm |
They corrode, badly.
10th May 2021 6:07pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
If TPMS is disabled, then get them replaced with rubber ones as soon as. They have been know to break and if they crack ot break when driving you don't want to end up wrecking a tyre or alloy.
10th May 2021 8:44pm |
Thanks everyone for your replies and advice. All replaced with old style valves today. One less thing to be paranoid about! 2011MY 4.4TDV8 Autobiography Baltic Blue
11th May 2021 5:25pm |
