Home > Technical (L322) > bluetooth |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
My iPhone connects 99% of the time without issue, so it may be a phone problem. Try deleting the pairing fom the phone and then repairing to see if that helps, also check you have the latest software updates running on your phone.
14th May 2011 6:08am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
chesh, its a known problem that if you switch of the BT on your phone after leaving the range ,when you come back you will have to pair up again...i believe a software update from the dealer solves this but they do charge for this... |
14th May 2011 7:41am |
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 |
My desire does the very same thing. I think it's to do with the phone and not the car. It's stays paired but every time you will have to enter the code to connect to the car. Never had this problem with my phone before the htc (blackberry bold). cheers Ex FFRR 4.2 Supercharged www.thecarpetfitter.co.uk |
14th May 2011 4:27pm |
chesh Member Since: 13 May 2011 Location: st helens Posts: 17 |
Well, it sounds like a phone issue, I thought it was only the i phones that had bluetooth issues, I will get intouch with HTC and see if they can throw some light on the matter and if I get it sorted I will post it. Thanks for your replies, Its a great site with lots of helpful people.
14th May 2011 6:07pm |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 |
Had the same issue with my Samsung Omnia7. Software update fixed it and enabled phonebook access too. Thankfully I got the dealer to do this before parting with cash for the car so it was free.... |
14th May 2011 8:21pm |
cheers , I will also give my local landrover a buzz to see if they can do an update, I will let you know, thanks for the feedback.
14th May 2011 9:07pm |
I believe wiggs can do an exchange unit for less than the dealers charge to update the it.
14th May 2011 9:11pm |
thanks for that, I was just reading about updating my analog to digital, may be I need to do it all in one go, I would like digital tv,
14th May 2011 9:30pm |
