Home > Maintenance & Mods (L322) > Binding rear brake tips... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
You need to take the slide pins out and make sure they are free. Sticking slide pins are usually the cause of overheating. John
22nd Apr 2021 8:04am |
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 54 |
Thanks Weegie
22nd Apr 2021 8:17am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
Its worth also checking piston condition too if you've got potentially binding brakes.
22nd Apr 2021 8:28am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
For what they cost l would just replace both rear callipers. |
22nd Apr 2021 9:13am |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 |
Good advice
22nd Apr 2021 12:29pm |
All useful info - thanks gents.
22nd Apr 2021 2:20pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 |
One of the site sponsors , Euro car parts, there quite a few specialist LR prts suppliers, or like me sometimes a small family independent motor spares shop. I have not bought original LR brake parts, but always use makers that guarantee the same or higher quality.
22nd Apr 2021 2:34pm |
I got my brake parts from Duckworths (site sponsor), together with the 2 rear flexable pipes. |
22nd Apr 2021 6:38pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
get a pair new on ebay for £75. many aftermarket ones are steel but they work fine 2010 VSE [Roger] |
23rd Apr 2021 7:04am |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 |
Advanced Factors - top quality parts and service |
24th Apr 2021 4:58pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 |
Yes the callipers may be fubar but when doing the cleaning did you have the carriers off. The bit where the pad sits rusts and needs a good wire brushing when reassembling. Much easier to do it with the calliper carriers off the car.
24th Apr 2021 5:23pm |
Thanks gents.
1st May 2021 2:31pm |
If the carrier holes for the slide pins are not worn, then you can get a new carrier pin set with all parts needed, cheap and easy to do, no need to renew the carrier itself.
1st May 2021 3:33pm |
OP here.
11th May 2021 6:01pm |
