![]() | Home > Maintenance & Mods (L322) > Binding rear brake tips... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
You need to take the slide pins out and make sure they are free. Sticking slide pins are usually the cause of overheating. John
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 54 ![]() ![]() |
Thanks Weegie |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 ![]() ![]() ![]() |
Its worth also checking piston condition too if you've got potentially binding brakes.
For what they cost l would just replace both rear callipers. |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 ![]() ![]() ![]() |
Good advice
All useful info - thanks gents.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
One of the site sponsors , Euro car parts, there quite a few specialist LR prts suppliers, or like me sometimes a small family independent motor spares shop. I have not bought original LR brake parts, but always use makers that guarantee the same or higher quality.
I got my brake parts from Duckworths (site sponsor), together with the 2 rear flexable pipes. |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
get a pair new on ebay for £75. many aftermarket ones are steel but they work fine 2010 VSE [Roger] |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 ![]() ![]() ![]() |
Advanced Factors - top quality parts and service ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
Yes the callipers may be fubar but when doing the cleaning did you have the carriers off. The bit where the pad sits rusts and needs a good wire brushing when reassembling. Much easier to do it with the calliper carriers off the car.
Thanks gents.
If the carrier holes for the slide pins are not worn, then you can get a new carrier pin set with all parts needed, cheap and easy to do, no need to renew the carrier itself.
OP here.
