Home > Off Topic > curious |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35330 |
most have carpets in their homes and so generally you dont wear outside shoes inside, so why have carpets in your car? ... - .- -.
19th Apr 2021 1:07pm |
thats a thought, laminate wood flooring in the FF instead of carpets...easier to clean ? ... - .- -.
19th Apr 2021 2:29pm |
....and, why cant you buy single carpet mats for the drivers side only instead of having to buy the whole set... ... - .- -.
19th Apr 2021 2:34pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 769 |
The single carpet mat question is one I've thought about on a number of occasions. I bet manufacturers would make more money as you're more likely to buy the one mat you need rather than live with it because of the cost and wastefulness of replacing a full set.
19th Apr 2021 2:46pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
Am I missing something? or is someone putting something extra in the coffee at work Stan?
19th Apr 2021 2:49pm |
hhmm, slippers with a range rover logo... ... - .- -.
19th Apr 2021 2:50pm |
Range Rover slippers!!!!!!!........NURSE !!!!!!!! |
19th Apr 2021 3:23pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Save the good mats for best. Replace all the downstairs carpet with wood and tiles, then cut up the old carpet into drivers side shapes, and you will have an endless supply of replacement disposable drivers matts. Tbh why bother replacing the flooring in the house, far less important than the matts for the fattie.... There is nothing that can't be fixed with a hammer😜😜
19th Apr 2021 4:23pm |
19th Apr 2021 4:25pm |
Privanthe Member Since: 18 Apr 2021 Location: Linlithgow Posts: 63 |
I tend to put rubber mats in everything out of habit, even though a small carpet cleaner would make quick work of mats.. |
20th Apr 2021 12:51pm |
107SW Member Since: 03 Jan 2016 Location: Yorkshire Posts: 41 |
Is it excessive to protect my Land Rover rubber mats with older rubber mats on top? (& perhaps some cardboard also for extra protection!!)
22nd Apr 2021 8:20pm |
