![]() | Home > Range Rover Classic > Range rover Classic 3.5 Efi Engine RPM problems |
chinkoa Member Since: 17 Jan 2014 Location: West Yorkshire Posts: 34 ![]() ![]() ![]() |
I have an engine RPM problem. My engine will not go above 3000 RPM. Either stood in the drive. On the road when I kick it down it will not rev above 3000. It's lively enough going upt to 3000. through the gears (Auto) then it just not wants to know.
It' the early Flap type MAF.
Jon,
Car is fitted with a landrover recon unit. 4CU PRC7440 84941A.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 499 ![]() ![]() |
Not sure, I don't know much about pre-14CUX Lucas systems. The 14CUX has a road speed sensor to limit top speed on 4x4 vehicles, this can work in conjunction with a gear position sensor.
I've done a bit of googling on your behalf and general thoughts on this system for these symptoms are:
Worth a read on how to test the Flappy AFM:
Hi Jon,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8449 ![]() ![]() ![]() |
At least it's fixed and has had a good service as well... |
So I was on the right track with my last paragraph in the post above !! ![]() ![]() ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
