Home > Range Rover Classic > Range rover Classic 3.5 Efi Engine RPM problems |
chinkoa Member Since: 17 Jan 2014 Location: West Yorkshire Posts: 34 |
I have an engine RPM problem. My engine will not go above 3000 RPM. Either stood in the drive. On the road when I kick it down it will not rev above 3000. It's lively enough going upt to 3000. through the gears (Auto) then it just not wants to know.
13th Apr 2021 9:35am |
It' the early Flap type MAF.
13th Apr 2021 12:04pm |
Jon,
13th Apr 2021 12:13pm |
Car is fitted with a landrover recon unit. 4CU PRC7440 84941A.
13th Apr 2021 12:28pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 421 |
Not sure, I don't know much about pre-14CUX Lucas systems. The 14CUX has a road speed sensor to limit top speed on 4x4 vehicles, this can work in conjunction with a gear position sensor.
13th Apr 2021 12:47pm |
I've done a bit of googling on your behalf and general thoughts on this system for these symptoms are:
13th Apr 2021 1:11pm |
Worth a read on how to test the Flappy AFM:
13th Apr 2021 1:17pm |
Hi Jon,
19th Apr 2021 8:53am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
At least it's fixed and has had a good service as well... Pete
19th Apr 2021 9:53am |
So I was on the right track with my last paragraph in the post above !! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
20th Apr 2021 8:23pm |
