Home > Technical (L322) > +ve wire from alt/starter motor/battery replacement CLOSED
Dughall
United Kingdom 2006 Range Rover Vogue SE TDV8 Stornoway Grey
Good Morning,
A newbie here and 3 months into my 1st L322 and this site is an utter goldmine of info.
Has anyone replaced the +ve wiring from alternator to starter motor to battery?
I have taken the old alternator out and the +ve (red) cable hadn't been screwed on properly which resulted in the rubber boot melting completely, the casing around the +ve screw thread melted and the +ve wire brittle and dare i say crunchy to touch.
I have a replacement cable ordered and the local garage has quoted £550 (circa 10 hours) to replace it.
If anyone has done it before, is it a DIY job?
Cheers, D "Things don't just fall off in your hand.....unless you own an L322!"
2006 3.6 TDV8 Vogue SE Stornoway Grey
Post #589647 31st Mar 2021 10:58am
I've never done it your engine but I can't see it taking anywhere near 10 hours, however it is routed you can pull a fish wire through with the old one and pull the new one back through...
10 hours seems like 8 1/2 too long to me... Thumbs Up Pete
Post #589653 31st Mar 2021 11:06am
Dughall
That's great @Haylands much appreciated!
Did think that might be the case but wanted to check if it was an 'engine out job' Big Cry
Thanks again,
Post #589654 31st Mar 2021 11:09am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Do it yourself mate. I had to pay some one to do my alternator but when it went again I thought I'd do it myself. Had it all off swapped and replaced within 2 hours. Longest part was trying to get the viscous nut to break with out the correct tool
Post #589670 31st Mar 2021 12:56pm
Dughall
Thanks Bean,
Yeah, had the alternator out and yes my knuckles suffered colossal damage whilst taking the viscous fan off Censored
Going to try the fishing wire trick as i can't see where the cable goes behind the engine after it attaches to the starter motor behind the front right wheel.
You would think the alternator was made of gold at how well they have hidden it away! Rolling Eyes "Things don't just fall off in your hand.....unless you own an L322!"
Post #589671 31st Mar 2021 1:01pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I would hope they quote it based on autodata or whatever it is called. I've not done it on this car but even on my daughters Golf MK2 it took me a while to route it properly, and deal with the various clips and taking parts off and on to get it to go in place. Clearly the owner before us took a shortcut and just did a throw it in and hope it sticks job...
Having dismantled the dashboard now, and seeing how some of the British engineers working on designing and building these cars thing, that quote doesn't surprise me at all.
Post #589675 31st Mar 2021 1:20pm
Fish tape has nothing to do with fishing.... Thumbs Up
https://www.amazon.co.uk/Silverline-868726...B000NBTP8O Pete
Post #589687 31st Mar 2021 2:13pm
Dughall
Thanks Rolling with laughter
My mistake in typing it. Would have been interesting seeing actual fishing line slicing through the rest of the cables though!
Cheers Bl4ckD0g - the replacement does have 3 of those clips so borrowing a mates endoscope to follow the current setup so I know where things go.
Will upload the pics for others to use. "Things don't just fall off in your hand.....unless you own an L322!"
Post #589692 31st Mar 2021 2:38pm
Dughall
So...
Apologies for the delay in updating. Kids off school etc etc..
Cable replaced but it wasn't running around the back, it actually runs under the air intake across the front bottom (ooh er..) and then back to the starter motor and alternator.
Part number is YMS 500280 if anyone needs it (fyi - different models / years / etc. have different parts so check first).
That however, has not fixed my original issue which is that when i am driving the Rangie park up and then restart it within a couple of hours (engine still warm and temp needle above zero) i start getting the blackpool illuminations.
This only happens when pondering along under no pressure. If i continuously tap the accelerator or brakes or on a bendy road its fine... Confused
Time to check the fuel pumps. I do get a whole load of error codes on my iCarSoft V2.0 tool but the vast majority are panic codes coming from the engine going into limp mode. The two that stand out are the Fuel Pressure Line too low and Injector Pressure too low.
Will keep you posted. "Things don't just fall off in your hand.....unless you own an L322!"
Post #591430 16th Apr 2021 3:08pm
dhallworth
Have you checked the alternator is definitely doing what it should? A friend of mine had all manner of problems with a 2007 TDV8 and it turned out it was the output from the alternator messing around... it was an alternator that hadn't long been replaced too! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #591436 16th Apr 2021 3:44pm
Dughall
Thanks @Dhallworth - will check that.
Also going to check the serpentine belt too, as the issue only happens when the engine is at running temp, i wondered if the belt was slipping when it heats up. I know it took me ages to remove the viscous fan (without the specialist tools) and therefore i had the belt slipping when i hit things with a hammer Surprised "Things don't just fall off in your hand.....unless you own an L322!"
Post #591684 19th Apr 2021 8:19am
cass
Is P023 one of the codes that you’ve got?
Post #591695 19th Apr 2021 9:26am
Dughall
Sorry, thought i had closed this.
Update: Very embarrassingly the fault was a flat tyre..... i know - what a muppet.
Turns out p/o had changed the wheels and bypassed the sensors so that they remained at a default pressure. Then when the tyre went flat the cars ECU's thought something serious was happening because as far as the readings were stating the tyres were fine.
Censored "Things don't just fall off in your hand.....unless you own an L322!"
Post #602477 1st Aug 2021 1:07pm
Well it sounded like you needed a new lead anyway so no harm done...
Every person who works on cars, be it their own or as a job, has missed the bleeding obvious more than once..... Pete
Post #602488 1st Aug 2021 2:13pm
