Home > General > Vogue v Vogue SE
Page 2 of 3 <123>
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Oh I meant to ask if anyone has an opinion on the Deployable Steps ?
Are they worth the extra compared to the fixed ones ? Are they reliable ?
They look like they give you a better foot up than the fixed for anyone who struggles to climb in to the height.
Post #63594 12th May 2011 12:58pm
johnson1
I wouldn't bother with deployable side steps. They are expensive, have to be removed if a tyre needs changing and don't really offer any real benefit. At access height the vehicle is easy enough to get into.
Post #63595 12th May 2011 1:13pm
johnson1
RE: Warranty - from what I've heard very expensive - circa £900 and doesn't cover a lot - a lot will come under 'wear and tear.' Had it on our Defender which was about £700 but crap.
I'd still go SE but try try try and get a 4.4 if you can.
Post #63596 12th May 2011 1:15pm
Rolo
Quote:
Spoke to a RR technician today and he reckons the deployable steps don't need to be removed to jack up......
Can you let me know why you say they do have to be removed ?
thanks.
Post #63689 12th May 2011 9:18pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
thanks.
It says so in the handbook
Post #63692 12th May 2011 9:22pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
what happens if you need to change a wheel at the side of the road??
Post #63696 12th May 2011 10:13pm
johnson1
thanks.
P241 of the Handbook for 2011 Range Rover:
DEPLOYABLE SIDE STEPS
If the vehicle is fitted with the optional deployable side steps, DO NOT attempt to jack up the vehicle. The side steps must be removed before jacking can proceed. Refer to the information supplied with the side steps for removal details. Alternatively, refer to your Warranty Benefits book and contact the appropriate recovery service for assistance.
Post #63697 12th May 2011 10:13pm
johnson1
You have to remove the side steps or call LR Assist to get them to come and do it for you. This alone makes the prospect of side steps pointless.
Post #63698 12th May 2011 10:14pm
Rolo
I think you can still jack, but you have to use the "garage" jackinh points instead of the usual ones which I presume would be behind the steps.
I read it somewhere on another post, but can't find it !
But, that would seem you'll need to carry a hydraulic jack with you and clamber underneath to get to the points suitable.
Post #63700 12th May 2011 10:35pm
johnson1
Yes, and also if you jack up with the side steps and mess them up your warranty won't cover you.
Post #63710 13th May 2011 6:28am
Fox
Sorry, that make makes the option of fitting them on a vehicle with 4x4 capability a complete joke. Rolling Eyes
Post #63711 13th May 2011 6:29am
johnson1
Yeah I agree!
Post #63714 13th May 2011 7:18am
Tomw2000
2011 Range Rover Vogue TDV8 Java Black
Trommel wrote:
As has been said, the leather is much nicer but I don't think the premium of a new SE is worth it.
This (and obviously it's each to his own). I went for a 'standard' vogue with a few bits added.
Paying more for (definitely nicer) leather, heated/cooled seats and adaptive cruise (which I have had before), didn't do it for me.
I'm not convinced you'd get the difference back on future values...but happy to be proved wrong.
Don't worry re the battery probs. I did, but am happier about it now (having had an initial semi fix and having had it explained properly.). NB the car never broke down or failed to start. I just sometimes get the 'battery low start engine' warning.
Post #63783 13th May 2011 1:16pm
johnson1
I agree with Tomw2000. The jump from Vogue to Vogue SE is not as justifiable as Vogue SE to Autobiography IMO.
Post #63786 13th May 2011 1:24pm
Rolo
Thanks again everyone for all your thoughts & input.
Just one other thing, I went to check out a standard Vogue today and have to admit the leather isn't quite so nice, although one with perforated seats added was nearly as nice as the SE and as comfy.
I haven't found a dealer yet that has a new vogue or SE in together to actually compare side by side.
Does anyone know if the door trims / dash are any different ? I saw a vogue with ivory leather / black piping - definately not my thing and I personally thought it looked cheap & nasty on the door trims (that was a new 2011 model) A 2010 SE I looked at did look far classier, although it was in my prefered colours Jet/Jet with ivory head lining - it just seemed to gel together so well. So not sure if it was just the colours putting me off in the vogue or if indeed it has a cheaper finish on the door trims...... Confused
Post #63812 13th May 2011 3:22pm
Page 2 of 3 <123>
