![]() | Home > General > Vogue v Vogue SE |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
I wouldn't bother with deployable side steps. They are expensive, have to be removed if a tyre needs changing and don't really offer any real benefit. At access height the vehicle is easy enough to get into. |
RE: Warranty - from what I've heard very expensive - circa £900 and doesn't cover a lot - a lot will come under 'wear and tear.' Had it on our Defender which was about £700 but crap.
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
Spoke to a RR technician today and he reckons the deployable steps don't need to be removed to jack up...... Can you let me know why you say they do have to be removed ? thanks. |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
It says so in the handbook |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
what happens if you need to change a wheel at the side of the road?? |
P241 of the Handbook for 2011 Range Rover: DEPLOYABLE SIDE STEPS If the vehicle is fitted with the optional deployable side steps, DO NOT attempt to jack up the vehicle. The side steps must be removed before jacking can proceed. Refer to the information supplied with the side steps for removal details. Alternatively, refer to your Warranty Benefits book and contact the appropriate recovery service for assistance. |
You have to remove the side steps or call LR Assist to get them to come and do it for you. This alone makes the prospect of side steps pointless. |
I think you can still jack, but you have to use the "garage" jackinh points instead of the usual ones which I presume would be behind the steps.
Yes, and also if you jack up with the side steps and mess them up your warranty won't cover you. |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Sorry, that make makes the option of fitting them on a vehicle with 4x4 capability a complete joke. |
Yeah I agree! |
Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202 ![]() ![]() |
This (and obviously it's each to his own). I went for a 'standard' vogue with a few bits added. Paying more for (definitely nicer) leather, heated/cooled seats and adaptive cruise (which I have had before), didn't do it for me. I'm not convinced you'd get the difference back on future values...but happy to be proved wrong. Don't worry re the battery probs. I did, but am happier about it now (having had an initial semi fix and having had it explained properly.). NB the car never broke down or failed to start. I just sometimes get the 'battery low start engine' warning. |
I agree with Tomw2000. The jump from Vogue to Vogue SE is not as justifiable as Vogue SE to Autobiography IMO. |
Thanks again everyone for all your thoughts & input.
