Home > Maintenance & Mods (L322) > Battery drain ... once again!
lilico64
France 2003 Range Rover HSE Td6 Adriatic Blue
Hello, despite a second battery relayed on permanent positive in the trunk of the truck, the td6 struggles to start on cold mornings. A hint: the blower often starts on its own in the morning (although I turned it off the night before) when I start the engine ... any ideas ??
Post #588186 20th Mar 2021 6:47pm
Could well be a faulty Final Stage Resistor, the component that controls the blower fan speed. Common problem causing battery drain.
If you do a search on here, plenty of information.
You could try removing fuses F12 10A and F34 7.5A and see if the problem goes away.
These fuses provide supplies to the FSR.
Post #588193 20th Mar 2021 7:19pm
lilico64
I had changed the hedgehog last year ... not easy ... but thanks for the tip: I start with the fuses and I'll see !!
Post #588303 21st Mar 2021 6:36pm
lilico64
Hi, you were right: it's the fsr that fails ! I am disappointed by the short time that my replacement hedgehog has worked... : an idea or advice about the brand of the new one that I'll order ?
Post #589159 27th Mar 2021 7:57am
IIRC the original was a Bosch... Thumbs Up Pete
Post #589167 27th Mar 2021 9:01am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
I had 3 drains on my RR (look for my older posts as cant remember what they were). 1 was FSR, one was the BCU and cant remember the 3rd, maybe headlight washers?
Just found a reply from NICEDAYFORIT who was a huge help, this i his words:
Fuse 28 headlight washers/wipers
Could be a faulty headlight washer/wiper relay allowing current to pass.
Fuse 27 glove box light, interior lights, windscreen washers and analogue clock. All common to BCU.
Fuse 12 ac and heated front seats. Supplies ac blower motor.
Almost certainly faulty FSR.
Post #589230 27th Mar 2021 2:07pm
